1 - 20 of 27 Posts
i have a 1990 300zx with 165,000 miles on it. i've been having difficulties getting my car started. i would go turn my accessories on and everything would be ok. i'd go to start it, and my car would be completely dead! no click, no turn over......dead. it was suggested to me that i should change my battery, but my battery has tons of juice. i had it hooked up to another car to see if it would start, nothing happened. some people say it could be the ignition switch, others say its a faulty alternator. might not be either. could anyone shine some light on this situation for me?
well, around the same mileage, my 90's ignition lock cylinder went out, accessories would be on, but it wouldnt start the car. im sure its the lock cylinder.
if not it might be your alternator, but i doubt it.
reply from zcarobsession
if it is the lock cylinder, would that prevent you from taking the keys out of the ignition? the keys are stuck, and it seems to me that when the car was started, the keys came out. its dead now, and the key release button seems to be stuck....or doesnt release the keys.
not really, mine did it sometimes but i dont think thats the case... you said your accessories turn on but the car wont crank atall or show signs of it. so im betting its the cylinder
well, the accessories would work only when i didnt attempt to start the car. once i attempted to start the car, everything would go dead, accessories included. the accessories would not work after attempting to start the car. im hoping that this problem has nothing to do with other problems i have with this car.........
high rpm's while driving, jumping mph gauge, seems like the car wouldn't shift outta second gear. higher gas mileage, but less power. stalling at stop lights(sometimes while driving). power steering would kick out....etc. i have a trouble code on my diagnostics, but thats been determined as faulty O2 sensors(i hope). yup, my car has a long way before it reaches full racing potential. i hope that i can fix it, i love my car, always have loved Z's.
well i will tell you one thing for sure, you will have to replace or rebuild your tranny soon. 1990 auto trannys had alot of issues. mine did the same urs did, til one time on the freeway it would never leave 2nd. and mine went out around the same milage too. sorry buddy. 1k its gonna cost you, unless u do it yourself.
thank you shadow Z, as long as i know whats wrong with my car, i can fix the right things. my fear is fixing something that doesnt need attention, and wasting money. i will reply with news of my car once i've installed parts that i've ordered after the storm subsides here. [email protected], i will look into that, ill let you know......thank you.
hmm, i wish i could, but i had nissan do it for me, this was before i invested in a service manual and rebuilt my Z. ill look for my FSM and see if it say in there.
Discussion Starter · #13 ·
question.......i took apart my ignition, and replaced the switch, nothing happened. but i noticed a small white box connected to my ignition which i believe to be my factory alarm. this alarm i thought was disconnected, but could it be this small alarm box preventing me from starting the car? i just bought a battery, so it couldnt be that. i noticed a red button inside the alarm box.....i pushed it, and my keys came out. i dunno, im just frustrated because i have no car. argh! by the way Shadow Z, that site helped a lot, thank you.
ok, sorry i didnt think about it before, but if it isnt your alarm thats preventing you from starting it, and ur cylinder is ok, then are you sure your tranny is all the way in P.. i noticed your Auto and sometimes its not slammed into park enough
Discussion Starter · #18 ·
i checked the links, all fine. i think i know what the problem is, but no idea how to fix it. i believe it is my anti-theft system. theres something wrong with the system, so its cutting all power to the car before i can turn it over. i removed the anti-theft relay, and went to start it. it didnt cut the power, but when i went to turn it over, it displayed "security" instead of cutting the power. i put the relay back, and the power was cut. anyone have this same problem? or any way i can fix it?
Discussion Starter · #19 ·
this car sux!!!!! i love Z's, but they are a big pain in the a$$ to fix. i read up on my theft warning control unit, and it told me to cut the 3rd wire on the 16-pin connector to cut the connection to the ignition switch so it wouldnt shut off. i did it, and went to start it up, it makes a weird noise when turning it over, then shuts off. there is also humming coming from where the starter is..............so maybe its the starter. what do y'all think?
i think u've delt with it long enough, spend 67 dollars and have nissan fix it.
1 - 20 of 27 Posts
