I'm looking at a standard 1990 300zx twin turbo, its got 120 000kms on it and maintenance has been done recently (belt, battery, pcv valves). considering the kms does anyone have any suggestions for what i should look for when i check the car out? are there some common problems with this particular yr? are there any known problems with the T25 turbos? i looked everywhere and couldn't find much for known problems so i figured may aswell ask the ppl that own some 300s just to be sure.
hings to keep in mind -
1990 had the most problems - from information I have, 1993-1996 are the best models.
Most I've been involved with seem to have some type of power steering issue.
Also check for leak issues in trunk (foggy tail lights ).
Make sure the Ignition Module has been replaced or is the Nissan Equip, you do not want the Mitsubishi one, they fail and will leave you stranded. Make sure maintenance records are good - timing belts, air and fuel filters can make or break cars performance
