Well I was driving my car just fine like any other day had it for a whole year and have had no problems at all it was driving good all day no problems at all at the end of the day I was on my way back home on the freeway all of a sudden the dash lights went extra bright then the car lost all power and shut down so I pulled over opened the hood and the negative battery terminal was off the battery it has happened to me a few times before and i would just put it back on the battery and it would start right back up. But this time it was cranking over but wouldn’t start now so I got it towed home tried to get it started no luck so I bought a new distributor and cap new spark plugs / wires , ignition coil new battery. Then installed all of that and even did a oil change and (it started up ran fine) took it out for a few hours then boom happened again lost all power and won’t start it cranks over and now I don’t know what the problem could be
***Car has: Gas in the tank. Has spark. It is definitely pumping gas. Has air flow. Battery has a charge. All the fuses under the hood are good. Starter seems good because it's cranking. Someone please help me😂 thanks
