1 - 8 of 8 Posts
Ok here goes, i have a 1987 nissan pickup with the 2.4, Z24 engine. The other day is just shut off while i was driving it and won't start now. I thought it might be the fuel pump because i couldn't hear it come on, so i check the voltage at the fuel pump and nothing even when trying to start it. i check the fuse and it is good and it has 12V on it, so any suggestions? anything help would be greatly appreciated. thanks jason.
Sentra Specialist
i have a 85 if you look under the passenger seat you should find a relay replacing that should help
This is true for the 720 pickups [through 86] but the 87 is a D21 Hardbody. They don't have the fuel pump timer relay problem that the 720 model carbureted trucks had.
Check for corroded terminals/wires at the fuel tank sending unit [on top of the tank]. This is a common failure on the D21's. Change the fuel sending unit [or complete sender and fuel pump assembly as most dealers sell it]. Otherwise check the circuit from the fuel pump relay back to the sending unit.
I own a 1987 D21 that has an intermittent fuel pump failure. I have a 100 percent rate of successful resolution of this problem by doing the following:
Use palm of hand or medium stick and strike the fuel tank briskly one or two times.
My assumption is that some aspect of the electric fuel pump or a filter becomes stuck/clogged and the sudden jar resolves the problem.
Eventually, I may replace the fuel pump. For now this works and the failure is about once for every 100-200 miles of driving. No other obvious cause and effect observable thus far. I am the sole owner of the truck and perform nearly all maintenance.
Failure only occurs on restart, not while in motion.
Nissan Picjup Truck gasoline tank
I have a 1990 Nissan pickup and the fuel pump and gas tank was filled with a brown syrup like substance in the tank.....This vehicle has been sitting for 7 years and I thought the gas went bad. Have you seen anything like this when changing the fuel pump? I am changing the fuel pump and cleaning the tank. This is the second time I have seen this in a gas tank from a vehicle stored for a long time. Any idea?
1 - 8 of 8 Posts
