Well I figured i'd try to get some help from every one here. Ive tried just about every where else.
Ok I got a 1986 Nissan 4x4 HB says XE on the door. It has a Z24 motor in it. My problem is the Vacuum lines. I know its the problem because if I switch them around I can make the truck run alot better.
Problem is I have no idea where they go and I been unable to find a diagram the truck is set up with a throttle body. The air cleaner has a clip that 3 or 4 houses plug into and I been switch those around until the motor will atleast idle.
Any one have a diagram I can go from or any information that might help??
Thanks in advance.
Thanks in advance.
