1 - 9 of 9 Posts
Guys,
I've owned an 84 200sx before this one (10 years and 280k miles)
and now this one (4 years 150K miles) never seeing this problem.
I parked the car the other night, went out in the morning, crank but no start.
Discovered when I turned the car on, fuel pump only ran for a minute. Checked the wiring, had 12 volts at the connector, but it went away when I plugged the connectors together. Pulled the fuel pump out of the tank, hooked to 12V, ran great. Found the the Ground wire under load was opening.
Jumped it to the Gauge ground, pump now runs but when I filled it with Gas today, it wouldnt start until I banged on the tank.
Question: Is there a fuel pump relay or what turns the power on to the pump.
Do the grounds all start from one place ? What should I check ?
Thx,
Andy
Discussion Starter · #2 ·
86 200sx Fuel Pump Problem
andy57s said:
Guys,
More Info 1/20/05:
I got 3 blocks from my house this AM when the car shutoff. Pump sounds
like it's running but under the hood I can hear a sound like gas running in the fuel rails and a solonoid click every so often. Any ideas ?
Thx,
Andy
More Info 1/20/05:
just replace the pump. I agree with Joel. if it acts broken, it most likely is. and changing wiring helps, so your wiring is most likely okay...don't ruin it making all kinds of wierd jumpers, invest a hundred bucks and be done with it. best of luck.
It's not the pump
Guys,
It's not the pump...... Pressure is 65 lb's when it's running.
It's just not getting the signal to turn on.
The fuel pump relay isn't switching on the Ground to the Pump.
Trouble is , I don't know where the relay is on the 86.
Anyone know ?
thx,
Andy
I had the same problem turns over has spark and everything just no power to the computer wich you need to get the fuel pump to work there is some fusiable links right between the right head light and the batterry replacle any of the ones that feel soft as they are blown or weak if the car does not start go under the hood and push on them and twist lightly it should start
Got a 84 s12 with a ka24de swap in it , car ran great for about 6 months , one day it started choking on the freeway to the point of stalling . Seemed I wasn't getting enough fuel , let the car sit for 15 mins and started it right back up . Next day I turn my car on after driving to friends house n it stalls going 25mph . Same thing just choked n died . Got crank spark n air . Have a feeling the fuel pump might have gone out or the fuel pump relay
1 - 9 of 9 Posts
