i have a 97 200sx se-r. the wire harness is fried, i have a wire harness out of 95 1.6 sentra. will they interchange or do i have to get the 2.0 harness? thanx for the info.
Discussion Starter · #2 ·
Wire Harness
I'm not sure but I think you would have to get the one off the se-r
but you should be able to tell by looking at them...
it should work from wut ive been told, only problem is the 1.l6 harness is usually shorter, but if u can lengthen the wires it should work. keep in mind i havent SEEN this but have heard it and i read it sumwhere too.... nissan performancemag maybe... anyways GOOD LUCK
bitter old man
The two harnesses are different, primarily due to sensors in different locations.
Cheap but difficult is to alter GA16 wire lengths, expensive but easy is new SR20 harness.
