1 - 7 of 7 Posts
ok I have a 03 Sentra Limited Ed. and im wanting to put K & N cold air intake, DC sport headers, a nismo cat back exhaust and a throttle body spacer. ive been told that if i do this i wont pass emissions. is this true? and what kind of results should i see if i do put them on? if someone could help that would be great.
If you area does the OBDII test then you can do the o2 spacer mod to get rid of the SES light that will throw w/ a catless header. If ur area does the sniffer test, then you can get a hi-flow cat welded into ur mid-pipe to pass emissions. The CAI, TB spacer, or cat-back exhaust don't effect emissions.
With a CAI, header, and cat-back exhaust u'll notice some gains. Not so much with the TB spacer.
However, getting rid of the pre-cat is a must for the longevity of ur engine. Also, loctiting ur butterfly screws so that they don't wind up in ur engine where they dont belong.
o2 spacer mod is to "trick" the second o2 sensor into thinking it's reading "cleaner" air which is the purpose of the second o2 sensor.
how-to for o2 spacer mod (AKA sparkplug anti-foulers): My SpecV - Your Ultimate Nissan SE-R Spec V Resource / Info
The SAFCII is to modify your AFRs for max power output (does not effect emissions). However, not a very worthwhile mod w/ just CAI,header,exhaust. Most have a SAFCII installed after cams at the very least when remaining N/A.
im not looking to get a whole lot of hp. mostly better mileage with a little bit more hp. and im trying to get it to run better and smoother so the car will last me a long time. is any of this even worth doing if thats all im looking for? if not, any suggestions?
1 - 7 of 7 Posts
