Sr20 timing problem and cam scarring - Nissan Forum
SR20DE/DET Engines 1991-2002 Silvia
post #1 of 1 Old Aug 21st, 2016, 11:20 AM Thread Starter
Hello everyone. I recently swap a sr20det engine in my s13. The swap was made by a mechanic who never worked on a sr20det before. He worked only on ca18.He said the timing is ok, he didnt check with a timing light, but for me, it wasnt confident. Anyway, after the swap the engine had some noises, and after 5 min he snapped the rocker arm from the exhaust cam on #1 cylinder. After this, all the work was done by a second person, which is the one who gave me the engine. All good. I start the car, and was running very weird. In the low rpm, was pretty ok, but after 3k the engine wont pass. I started checking myself all the things. I checked the tps, the cas, the iacv, etc...and i think my timing was not installed corectly. I took the valve cover off, and made some pictures. I count 19 dots between the cams, and the lob from the intake cam is not horizontally. Something is wrong. Please, tell me what you think? I checked the tdc with a long screwdriver, but i am not 100% sure that the previous owner put the tdc on the 2nd notch from the pulley and not on the first. Also, after checking the cams, i found some scarring on the exhaust cam lob from the first cylinder. How bad is this? Thank you all.
ViorelP is offline
  Nissan Forum > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
sr18 and sr20 cam shaft sunny gti/gti-r rep SR-Series Engines (DE/VE) 3 Mar 6th, 2009 07:56 PM
CAM TIMING TOOMUCH S14 240SX 1995-1998 1 Aug 20th, 2007 07:16 PM
Cam timing... DBSS_Gohan Z31 300ZX(T) 1 Oct 2nd, 2004 09:34 PM
Can an SR20 intake cam fit in GA16? Greg200SE-R GA16DE 1.6L Engine 11 Dec 8th, 2003 12:26 AM
cam timing htrdln GA16DE 1.6L Engine 5 Dec 16th, 2002 02:56 AM
You may post new threads
You may post replies
BB code is On
