Power Steering Pressure Hose - Nissan Forum
SR-Series Engines (DE/VE) Engine Discussion: G20, 91-94 Sentra SE-R, NX2K, 95-98 200SX SE-R, 98-01 Sentra SE
post #1 of 9 Old Jun 30th, 2003, 01:19 PM
sr20junkie
Guest
Posts: n/a
Question Power Steering Pressure Hose
Has anyone here replaced their Power Steering Pressure Hose? Mine has sprung a leak and is squirting power steering fluid all over the manifold and elsewhere. I bought the hose already and went to replace it but was worried about 2 things. First, the line is under high pressure and I don't want to have it blow up in my face. Second the bolts connecting it are too tight for me to loosen without bending the metal line running from the pump.
Anyone have any experience with this? I have a 1993 Sentra SE-R.
Thanks,
Jason
post #2 of 9 Old Jul 16th, 2003, 06:26 AM
(_(_)===D ~~~`nissantuner
nizmo559's Avatar
Hey guy I broke mine did you get your issue resolved yet. Let me know im trying to figure out what to do.I busted mine cuz it was so damn tight I should have used an air gun
Nissan Infiniti Owners
Fresno, Ca.
To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts.
‹^› ‹(•Ώ•)› ‹^›
nizmo559 is offline
post #3 of 9 Old Jul 16th, 2003, 08:16 AM
sr20junkie
Guest
Posts: n/a
Power Steering hose
No, I haven't fixed it yet. I am going to buy an impact wrench and see if that works tomorrow. I'll let you know if I have any luck.
post #4 of 9 Old Jul 24th, 2003, 09:15 AM
sr20junkie
Guest
Posts: n/a
Attempted to replace
I attempted to replace the hose over the weekend after buying a large air compressor and impact wrench. I was surprised to find that even the impact wrench didn't have the power needed to loosen the bolts.
I'm too stubborn to go to a mechanic at this point but after I destroy my car trying to get it off I might take it in.
post #5 of 9 Old Oct 20th, 2003, 04:22 PM
nizmo559's Avatar
Finally got it of with the impact wrench after destroying the return line which was another 40 bucks. But I can turn again. yay!!
Fresno, Ca.
‹^› ‹(•Ώ•)› ‹^›
nizmo559 is offline
post #6 of 9 Old Oct 20th, 2003, 04:40 PM
Datsun Guy
B11sleeper's Avatar
Send a message via AIM to B11sleeper
hmm I pulled my power steering and replaced it with a manual rack. I really like it now.
Maybe take the pump out and put penetrating oil on the bolts... sometimes a slow steady pressure will get it loose...
1981 datsun 210.
B11sleeper is offline
post #7 of 9 Old Oct 21st, 2003, 04:43 PM
nizmo559's Avatar
Yea if iwould have been patient instead of just going for the gold I might not have wasted so much time. For any of you guys having problems this is what you do for sure.
1. spray wd40 on the ball joint prior to
2. use only a impact wrench with lots of pressure
3. Dont buy a used ps line with a hole like I did make sure its in good shape.
4.If you think the metal return line will snap it probably will be carefull thats another 40-60 bucks depending where you get it at.
Lastly when putting it back on it has to be tight, there is a ton of psi going thru that line thats what makes ps work, and why it is so damn hard to get off in the first place.
Fresno, Ca.
‹^› ‹(•Ώ•)› ‹^›
nizmo559 is offline
post #8 of 9 Old Feb 27th, 2016, 04:31 PM
2005 Nissan Murano looking for estimate to replace steering fluid line, Ontario
clewis is offline
post #9 of 9 Old Mar 3rd, 2016, 07:03 AM
The power steering hose connects the power steering pump to the cylinders that enables a vehicle to turn left and right easily. If you are changing hose you should cover your face with thin visible cloth that will somewhat protect your face from oil. To loose the bolt hydraulic pressure is applied to the tensioner which stretches the stud thereafter the stud's nut wound down against the joint face, pressure is released and the tool will be removed.
derekbrian is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > SR-Series Engines (DE/VE)
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
