2.5L engine swap question - Nissan Forum
post #1 of 17 Old Jul 8th, 2011, 03:59 PM Thread Starter
I have a friend who ran his 2002 Sentra hot and fried the head. I found a 2.5l from a 2010 Altima. Will the 2010 2.5l fit in 2002 easily or even at all?
bjwelch76 is offline
post #2 of 17 Old Jul 25th, 2011, 11:21 PM
skatehard90's Avatar
Send a message via AIM to skatehard90
I'd also be curious to know the troubles involved with swapping in a newer QR25 (2007-2011). You'd be dropping nearly 2lbs per hp if the 200hp was placed into the 2700lb B15, no?
Mr. Cook
WRC--->my life, i never did believe in paved road systems :kiss:
skatehard90 is offline
post #3 of 17 Old Jul 26th, 2011, 08:57 AM
Sup Mod keeping the peace
rogoman's Avatar
The 2010 QR25DE should fit as long as the motor mounts are the same. Use the original existing wiring harness, sensors, ECU, intake/exhaust manifolds. Don't use any 2010 exterior accessories. I'm not sure if the 2010 engine uses any additional sensors.
KA-T for life, yo!
rogoman is offline
post #4 of 17 Old Oct 3rd, 2011, 10:42 PM
I know an 06 will work. That is what I PUT IN MY 02 SENTRA SE-R. I am not sure about the later engines. May be able to use long block only but do more checking.
64dodge540 is offline
post #5 of 17 Old Mar 27th, 2012, 06:31 AM
64dodge540 what differences did you find with the 06 engine?
btownpapi is offline
post #6 of 17 Old Mar 27th, 2012, 07:03 PM
2.5 engine swap
the 06 engine came out of a Altima with an automatic and the only thing I did was swap my flywheel and use my exhaust because the engine had an automatic behind it and the exhaust mainfold assy is different on the Altima. Otherwise I used the intake assy and all the sensors from the Altima and had no problems.
post #7 of 17 Old Aug 15th, 2012, 08:23 PM
dirty5thirty's Avatar
what about swapping the 2.5 from the 03 SE-R into a regular 04 sentra?
dirty5thirty is offline
post #8 of 17 Old Aug 15th, 2012, 09:28 PM
assuming your 04 regular Sentra has a different engine unless it is an SE-R too, you would have to get everything associated with a 2.5L in a Sentra because on your engine everything would be different. IF your car is an SE-R too then 03 to 04 engines are not a problem.
post #9 of 17 Old Apr 23rd, 2016, 03:17 PM
2002 Nissan QR25 engine is different. I had the same doubt but I have compared them before. I ended up buying a JDM Nissan QR20 engine from Used Japanese Engines | JDM Engine | Japanese Motors
jamescallowa is offline
post #10 of 17 Old May 1st, 2016, 09:54 AM
Registered User
was it a 2002 se r that you put the 2.0 engine in?
davidlmc is offline
post #11 of 17 Old May 7th, 2016, 03:46 AM
Registered User
is the nissan altima 2002 2.5L engine the same as the QR25?
I am trying to install a turbo kit on an ALtima 2002 2.5L
This is the kit: 02-11 Nissan Altima QR25 2.5L T3/T4 Turbo Kit - FastWayRacer.Com
cesarverah is offline
post #12 of 17 Old May 8th, 2016, 08:52 AM
rogoman's Avatar
Originally Posted by cesarverah View Post
is the nissan altima 2002 2.5L engine the same as the QR25? I am trying to install a turbo kit on an ALtima 2002 2.5L
The 2002 2.5 L is the QR25DE. Good choice on your turbo kit and good luck on installation.
Fuel management is the most important and also the most complex item with turbo charging. There are several ways to perform fuel management:
Management options are diverse. The cheapest option is the Rising Rate Fuel Pressure Regulator which automatically adjusts the fuel pressure according to the boost pressure; this is the most affordable way to provide the proper amount of fuel to a turbocharged engine, but are not the best. Digital options are the next step up, which include SAFC-II, AFR, and E-Manage. These are not terribly expensive, and provide the best fuel management for the money. These units digitally manage fuel flow, and provide excellent variability for the money. The next option is a chipped ECU. Jim Wolf Technology is the most famous provider of this service, but these are quite expensive and not user-reprogrammable. The best option is, of couse, stand alone fuel management. Stand alone is a complete ECU replacement. Companies such as AEM sell their EMS units which provide exactly what the name promises, All Engine Management. Stand alone is quite expensive, but can support extremely high horsepower applications while providing the greatest level of tuning flexibility.
KA-T for life, yo!
rogoman is offline
post #13 of 17 Old Jul 1st, 2016, 02:50 PM
Hello I have a Xtrail 2.5 2003 petrol manual code is QR25DE will any other engine fit in it as on Wikipedia it says other nissans use the same engine, does it have to be a 2.5 or can I put a 2.0 /2.2 in?
Click image for larger version
ID:	4393   Click image for larger version
Nissandriver2016 is offline
post #14 of 17 Old Jul 2nd, 2016, 08:05 AM
If wikipedia is your source look up Nissan X trail to see the different generations and their different specs. But again why? Most modders want to go for more power. I am pretty sure wiring and the ecu would have to change, and then you have to hope engine mounts, exhaust and a bunch of other stuff is the right fit. But I would be very curious to learn what all is involved from your experience. Good luck.
quadraria10 is offline
post #15 of 17 Old Jul 3rd, 2016, 05:10 PM
Thanks for your comment, it's finding an engine for 2.5 lol. I'm having the engine rebuilt I need a engine rebuilding kit. With Pistons, rings and gasket. Any ideas where does them. Where r u located?
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > QR25 2.5L Engine
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
