Head bolt washers - Nissan Forum
post #1 of 4 Old May 2nd, 2019, 06:29 PM Thread Starter
Head bolt washers
Just as the title im curious about head bolt washers. Working on a sentra with the 1.8 that the head gasket let go on. Normally I work on LS engines and rotaries but im trying to help a buddy out. I dont know this engine at all as far as the fine details. The maintenance is apparently not well kept up with as up top had a good bit of crud on and around the bolts. I pulled the bolts pulled the head and didnt notice until I started cleaning up and prepping to machine it that there were washers under the bolt heads. They stayed on the head in the gunk.
Well i guess when moving around I lost a few since I didnt know they were there. The new head bolts do not come with washers so I assume this is not a factory thing and something someone did last time the head was off since its been off before from the blobs of RTV everywhere. So before I slap this little micro engine back together are washers supposed to be under the bolts? If so ill go find some.
Brandon Brown is offline
post #2 of 4 Old May 4th, 2019, 09:54 AM
Sup Mod keeping the peace
rogoman's Avatar
According to the FSM, the head bolts use washers. You can use a flat METRIC washer found in most hardware stores.
KA-T for life, yo!
rogoman is offline
post #3 of 4 Old May 6th, 2019, 08:48 AM Thread Starter
Thanks for the reply I got it worked out but the exhaust cam broke unfortunatly while doing the chain.
post #4 of 4 Old May 11th, 2019, 05:22 AM
NF Mod/Nissan Master Tech
smj999smj's Avatar
I'd rather just get the correct washers from Nissan; they're only 50-cents a piece and you know they are the correct thickness and hardness. The other thing is that a generic washer with that size hole may be too large on the outside to fit in the recess.
smj999smj is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > QG18 1.8L Engine
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Head bolt washers MrFent GA16DE 1.6L Engine 9 Dec 19th, 2010 12:42 PM
ES MMI Washers acriml01 QR25 2.5L Engine 9 Feb 14th, 2005 10:40 AM
Headlamp Washers sentravis Cosmetic Mods 22 Jan 28th, 2003 02:49 PM
Oil Drain Plug - Use Crush Washers? DaveTV General Discussion 6 Jan 2nd, 2003 01:02 AM
Neon Washers Werewolfmage Cosmetic Mods 33 Dec 27th, 2002 09:28 PM
You may post new threads
You may post replies
BB code is On
