Frequent Rear Brake Replacement - Nissan Forum
post #1 of 2 Old Apr 22nd, 2019, 01:18 PM Thread Starter
I have a 2005 Altima and recently replaced the rear brake pad and rotors as suggested by my mechanic. After recalling I recently had brake work done, I found the paperwork from Feb 2017 for replacement of the rear brake pads and rotors. I can't recall replacing anything on the front brakes. This seemed odd to me since the front brakes should be performing more of the stopping. I would think the fronts would wear quicker.
Does replacing the rear brakes approx. 2 years old and only 10k miles seem quick? Is this indicative of another issue that may be causing the quick deterioration of my rear brakes?
Jathis
Jathis is offline
post #2 of 2 Old Apr 23rd, 2019, 06:42 AM
Depends. The best thing would have been to ask your Mechanic why they wore fairly quickly. What you don't mention is the climate you are in, nor the mileage and type of it you did. A delivery driver in the city will go through brake pads faster than someone who does a long highway commute. If you are in a maritime climate with lots of salt used on roads in winter, you will wear them out faster than places with less cold and snow and ice. If your car sits for long periods in a damp climate without being driven, they will wear faster. If you went for the cheapest rotors and brake pads you can get they will not last as long as an OE or first-rate set. If you don't have the caliper slides and pins lubricated once a year, its common for a pad to get stuck and wear prematurely. If you drive the vehicle hard you will also wear them a lot faster than someone who drives very slowly. Which brings us to, yes your brakes will wear faster if other suspension components are worn.
quadraria10 is offline
  Nissan Forum > Altima/Stanza > L31 2002 - 2006
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
2,5 Diesel 2010 frequent turbo problems HELP! fritz Pathfinder 0 Oct 7th, 2015 12:37 PM
X-Trail frequent brake disc imbalance arapak New Member Forum 3 Feb 26th, 2013 10:48 PM
Frequent stall at idle - '86 Bluebird. CCCMikey Classic Datsun 0 Nov 13th, 2010 07:13 AM
Rear brake disc replacement question vasek B14 95-99 chassis 7 Jul 26th, 2010 01:29 PM
Rough idle and frequent stalling imperium HB Truck 7 Nov 24th, 2008 12:39 PM
You may post new threads
You may post replies
BB code is On
