Brake Load Sensing Valve - Nissan Forum
post #1 of 3 Old Jan 21st, 2019, 04:46 AM Thread Starter
1998 Nissan Frontier XE, automatic, RWD, 2-wheel ABS
The brake load sensing proportioning valve is leaking at the plunger, and I don't want to take a chance with a used valve or with just bypassing the valve. Nobody seems to stock this part, #46400-8B400 or #4648B410 (seems to have399 7YC molded into it), but another vehicle seems to use a part that looks identical on the outside, the Mitsubishi 1986-2007 compact Triton pickup, part #MB618321 , and it's available everywhere. Is it a reasonable substitute?
larrymoencurly is offline
post #2 of 3 Old Jan 21st, 2019, 01:23 PM
Nissan Fanatic
Curly,
Check with Beelineparts.com they have free shipping and ConyersNissan.com on amazon once you get the right part #. One of the part #'s you gave is discontinued, so hopefully it has been replaced with a new part #. If no new part then maybe a salvage yard from a low mileage truck.
Good Luck,
Barney,
2013 SV V6/4L AT 2WD KC Frontier/Current; '93 Hardbody KC,2.4L/IL4,AT,2WD, O.O./20yrs./Sold
BRubble is offline
post #3 of 3 Old Jan 21st, 2019, 05:05 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
The 46400-8B400 is the one you need, as it's made for a Frontier with an automatic transmission. The 46400-8B410 is for a Frontier with a manual transmission. Both have been discontinued and were never available on the aftermarket, so used is the only option. The load sensing valve works like an extra proportioning valve for the rear brakes. As you add weight to the back of the truck, it will cause the bed to lower, which actuates the LSV to control adjust the front/rear brake bias. If there is enough of a difference between a manual trans Frontier and one with an automatic transmission for Nissan to have two different valves, then I doubt the one for the Triton would be the same as the Nissan valve. I wouldn't recommend using it, but that's your decision. If you can't source a replacement LSV, you would be better off eliminating it, altogether. It'll just operate like an older truck which didn't have an LSV.
smj999smj is offline
  Nissan Forum > Frontier Truck > General Frontier Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
load sensing proportioning valve issue dtom4 Pathfinder 0 Dec 27th, 2010 06:47 PM
Load Sensing Proportioning Valve ( LSPV) pacificsun HB Truck 2 Jun 9th, 2008 04:34 PM
Brake load sensing valve i r teh noobz J30 1989-1994 Chassis 1 Mar 3rd, 2008 04:24 PM
98 Pathy - Load Sensing Valve; broken bracket Darth Baiter Pathfinder 0 Jun 17th, 2007 09:03 PM
Looking for Nissan Load Sensing Valve...1976 620 pickup jbclem Classic Datsun 5 Jul 21st, 2005 06:59 AM
You may post new threads
You may post replies
BB code is On
