tachometer problem. - Nissan Forum
General 240SX/Silvia/S12 200SX For general 240SX/Silvia/S12 200SX discussion
post #1 of 9 Old Mar 21st, 2007, 07:55 PM Thread Starter
tachometer problem.
I own a 1995 200sx SE, automatic, and i have a problem with my RPM guage. It dosent work at all...I have not checked wiring in the back, but sometimes it decides to skip up and down (happens very rarely). Anyone else have this same problem? Answers or suggestions would be much appreciated.
Red200sx1987 is offline
post #2 of 9 Old Apr 22nd, 2007, 07:20 PM
wouldnt you know im having the same issue!
b-inky is offline
post #3 of 9 Old Jul 20th, 2007, 08:17 AM
It could be several things. The gauge itself, the computer, a short in the wiring harness..have you had a tech run a computer on it?
91240SXGuy is offline
post #4 of 9 Old Jul 23rd, 2007, 05:28 AM
hi all niissan lovers i got a question i bought a sport comp rev tacho off a mate it was on his cefiro rb20 i put it in my 180sx sr20det its 1000 rpm behind there is no switch for number of cylinders ive connect green wire to yelow wire with red stripe on ecu does it have to be calibrated or wired differently apreciate any help.
regards
dans180sx is offline
post #5 of 9 Old Apr 25th, 2016, 05:04 AM
Registered User
Unhappy Tachometer problem/ Rev counter
I have a Nissan 200 Sx 1999 Turbo. My Rev counter is going mad it is jumping all over the place does anyone have any ideas what could be causing this??
9849 Mortimer is offline
post #6 of 9 Old Apr 25th, 2016, 11:19 AM
And I'd add a speed transducer problem.
Without knowing more, by default each of these four components is equally likely to fail.
But, taking into account environment & complexity, and assuming more complex things are more likely to fail, then I assign
-gauge: 10% likely (It's in a benign environment.)
-computer: 50% (Benign environment but complex.)
-short: 15% (Anybody know the service lifetime or MTBF of a vehicle wiring harness?)
-transducer: 25% (it's in a hostile environment but not so complex.)
adding to 100%.
More info always equals better WAGs.
Make better decisions! Read
http://www.wiley.com/WileyCDA/WileyT...471908088.html
2003 Frontier, 2004 Impreza TS, 2013 Golf (gas)
OhmsLaw is offline
post #7 of 9 Old Apr 26th, 2016, 02:10 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
If it's a 1999 model, you should be your question in the B14 section. When Nissan brought back the 200SX name in the mid-90's, they applied it to the 2-door version of the B14 Sentra, which is quite different from the earlier 200SX's, like the S12 model.
To answer your question, most tachometer failures or improper operation are caused by a bad tachometer. The typical fix is to replace the tachometer, although they can be expensive. That said, the only way to be sure is to break out a copy of the factory service manual for your vehicle and do the appropriate diagnostic steps and circuit checks. Nico Club's site and NissanHelp.com have free downloads of service manuals.
smj999smj is offline
post #8 of 9 Old Apr 26th, 2016, 10:31 PM
jdg
I Live Here
Isn't there a bit of an "issue" with rotten solder joints on these instrument panels that'll cause the same thing?
Or am I thinking of one of my other vehicles again...
99% of the questions that are "STRANGE" have a dirt simple answer...usually answered by a dirt simple search.
To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts.
Is it just me, or does the majority overlook the obvious?
Somebody ate a whole bag of dumbass for breakfast.
Why do people continue to run a vehicle when a warning light comes on or starts flashing? Isn't that a clue that something is wrong and you probably should NOT drive it?
Is this whole car driving thing really freekin' brain surgery?
Here's something new for the crowd/clowns...
"A little bit of Google goes a long way!"
Ever notice the one post wonders for info on turbo'ing a GA16 are never heard from again after they figure out the cost???
And if you can read this, you don't need glasses! :)
And yes, I am diggin' it...
jdg is offline
post #9 of 9 Old Apr 27th, 2016, 07:28 PM
smj999smj's Avatar
I'm not familiar with the "rotten solder joint" issue on Nissans. There were issues with the threads where the bolts screw into on the back of the speedometer head causing poor contact issues, resulting in P0500 codes and/or intermittent speedometer operation. That didn't affect the tachometer, though.
  Nissan Forum > 240SX/Silvia/S12 200SX > General 240SX/Silvia/S12 200SX
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Unusual problem solved Zen31ZR Z31 300ZX(T) 2 Feb 19th, 2005 07:45 PM
Overheating problem.. What should I do next? alkon GA16DE 1.6L Engine 4 Jan 25th, 2005 10:05 PM
Problem with tranny... J30tour General Discussion 0 Apr 19th, 2003 10:50 AM
You may post new threads
You may post replies
BB code is On
