Engine shut off - Nissan Forum
post #1 of 6 Old May 23rd, 2019, 06:53 PM Thread Starter
Engine shut off
Today when I arrived at work my engine shit off as soon as I stopped. I could crank the motor but as soon as I places it in gear it would shit off again. After hours of looking at my car I noticed that I was 1QT low in oil. I'm curious if there is an emergency shut off feature to prevent the motor from seizing if there is low oil pressure. After I put a quart of oil in the vehicle acted like it never happened. I was able to drive my 80 miles home with no problem.
JahueC is offline
post #2 of 6 Old May 24th, 2019, 09:19 AM
Sup Mod keeping the peace
rogoman's Avatar
Please state the year,model,engine and transmission of your vehicle. Without this info, it's like shooting in the dark to help you with your problem. Did the oil pressure light come on? Also, did the "check engine" light come; if so, what were the ECU codes?
KA-T for life, yo!
rogoman is offline
post #3 of 6 Old May 24th, 2019, 09:40 AM Thread Starter
2015 Nissan Versa Note with 1.6L engine and CVT. The low oil pressure light never came on while driving to work. Also there were no codes stored. It's like the engine just shut off. There were no indications of any malfunction prior to the vehicle shutting off.
JahueC is offline
post #4 of 6 Old May 24th, 2019, 10:43 AM
rogoman's Avatar
I looked through the FSM for your vehicle and could not find an emergency shut off feature to prevent the motor from seizing if there is low oil pressure.
KA-T for life, yo!
rogoman is offline
post #5 of 6 Old May 24th, 2019, 10:49 AM Thread Starter
Maybe if was just low oil pressure. After I put a quart of oil in, the vehicle acted as if nothing was wrong. Seeing as the capacity is approx 3.5 qts and it was a quart low that seems to be a lot considering most vehicles have a capacity of 5-6 quarts. What are your thoughts?
JahueC is offline
post #6 of 6 Old May 24th, 2019, 03:43 PM
rogoman's Avatar
If you plan to check the oil pressure, here are the specs:
600 rpm: More than 14.2 psi
2,000 rpm: More than 42.6 psi
6,000 rpm: More than 56.8 psi
Oil capacity: unit: liter (US qt, lmp qt)
With oil filter change 3.5 (3 3/4, 3 1/8)
Without oil filter change 3.2 (3 3/8, 2 7/8)
Most Nissan engines have an oil pan capacity of 4.25 qts and up. Being that your engine was down 1 qt, that gives you 2 3/8 qts in the pan; not very much. Considering how high the oil pickup screen is above the bottom of the pan, you could well lose some oil flow intermittently, especially when hard accelerating; not a good thing. At least now you know to keep it full.
KA-T for life, yo!
rogoman is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Noise after engine shut off Rec DNA A33 2000-2003 Chassis 3 Apr 3rd, 2004 04:21 PM
noise after engine shut off Rec DNA General Maxima Discussion 1 Mar 8th, 2004 07:48 AM
Noise after engine shut off Rec DNA A33 2000-2003 Chassis 1 Mar 7th, 2004 10:10 AM
new 3.5 engine pings or ticks when shut off costen L31 2002 - 2006 2 Sep 2nd, 2003 06:18 PM
engine auto shut off upon started jackxwu Suspension & Brakes 0 Dec 7th, 2002 12:07 PM
You may post new threads
You may post replies
BB code is On
