Head gasket? - Nissan Forum
post #1 of 2 Old May 23rd, 2019, 03:00 PM Thread Starter
Head gasket?
Hello, Iam new here, I bought mint sunny n14 with 1.6 (I guess ga16de) and its eating water and the oil level is increasing, so I strated to disassemble the head, It could be only head gasket right? Btw how to loosen baked nut on egr valve? Do I need him that much? 😂 thanks
Marian Flimel is offline
post #2 of 2 Old May 23rd, 2019, 04:23 PM
Sup Mod keeping the peace
rogoman's Avatar
Did you first perform a compression test on all cylinders; it could verify the condition of the head gasket. If you find a weak cylinder or two adjacent weak cylinders, that can certainly signify a blown head gasket. It's also possible that there may be a crack in the cylinder wall or somewhere in the block causing the loss of coolant leaking into an oil gallery.
To loosen the big exhaust tube fitting on the EGR, apply some Liquid Wrench or PB Blaster to the threads, then tap the fitting lightly with a small hammer to set up a vibration allowing the Penetrant to do it's magic. Now use a very large adjustable wrench to loosen the fitting.
KA-T for life, yo!
rogoman is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
HEAD GASKET BLOWN 92 V6// K&N OR REPLACE GASKET mentawai69 HB Truck 0 Nov 16th, 2011 12:03 PM
Cracked head or Head Gasket lilhatch89 B15 2000-2006 2 May 9th, 2008 05:08 PM
96 Altima head gasket/head/heat damage problem? 96AltimaOwner U13 1993-1997 Altima 0 Aug 20th, 2004 08:58 AM
Leaking head gasket or cracked head... SuperHatch B11/B12/KN13 82-90 chassis 6 Nov 9th, 2003 01:33 AM
Resurfacing head for metal head gasket v8killer Forced Induction & Nitrous Oxide 1 Dec 7th, 2002 03:14 PM
You may post new threads
You may post replies
BB code is On
