radiator fan not working only when air conditioning switch is on Why? On my 1991 Niss - Nissan Forum
post #1 of 27 Old Aug 4th, 2012, 10:30 PM Thread Starter
Question radiator fan not working only when air conditioning switch is on Why? On my 1991 Niss
Need help trying to fiquire out why my fan is not working only when I put air conditioner on. There are two fans and both only come on when the ac is on. It seems to heat up only when the ac is off.I have a Nissan 1.6ltr sentra 4dr .You can email me back if you wish at [email protected] Thanks P
wrehab is offline
post #2 of 27 Old Aug 5th, 2012, 01:18 PM
EvilPotato's Avatar
the fans aren't supposed to be constantly on. they come on when the engine heats up to a certain temperature, or when you turn the air conditioning on.
"...and the Lord said to John, Come forth and ye shall receive eternal life, but instead John came fifth and won a toaster."
EvilPotato is offline
post #3 of 27 Old Aug 5th, 2012, 02:22 PM Thread Starter
Fans will not come on at all even if I idle the car till if gets too hot
My fandoesnt seem to come on at all even when I have idled the car to just below the h mark. The only time I see it come on is when the ac is turned on. Could this be a problem?
wrehab is offline
post #4 of 27 Old May 23rd, 2014, 04:51 AM
same problem here. fans won't turn on with a/c off even if temp rises.
doen is offline
post #5 of 27 Old May 23rd, 2014, 10:29 AM
Sup Mod keeping the peace
rogoman's Avatar
Check all the fuses in the engine compartment. There should be a relay box near the battery that contains two relays for the cooling fans; one of them may be defective. Not sure which one controls the fans when the A/C is off.
KA-T for life, yo!
rogoman is online now
post #6 of 27 Old May 23rd, 2014, 01:05 PM
Nissan Fanatic
b13er's Avatar
Garage
The first thing I would do is test the fan by applying direct power to it. Take some wires attach it to your battery terminals, and then unplug the fan and apply direct power to them. It might not make any difference since it's a fan, but try to use the correct polarity.
If it turns out your fans work fine with direct power, post back and I will find some other solutions for ya.
b13er is offline
post #7 of 27 Old May 24th, 2014, 01:25 PM
@rogoman , it has only one relay for the fans. the fuses are good.
@b13er , the fans are working with a/c on.
doen is offline
post #8 of 27 Old May 24th, 2014, 05:39 PM
Have you checked your temp sensor?
This is from the service manual for my 94, same engine.
worthirt is offline
post #9 of 27 Old May 24th, 2014, 06:18 PM
Rogoman is correct, there is more than one relay. Look at the wiring diagram from the service manual.
worthirt is offline
post #10 of 27 Old May 25th, 2014, 04:36 AM
is pin #14 on ecu a ground pin? i think that is my fan relay's trigger.
http://s3.amazonaws.com/2cp-images/q...6071/large.jpg
doen is offline
post #11 of 27 Old May 25th, 2014, 07:05 AM
I'll look, but why are you going after the ECU, have you checked the sensor yet?
to download the b13 (1991-1994) service manual, go here: Factory Service Manual
Just remember, these are big.
worthirt is offline
post #12 of 27 Old May 25th, 2014, 07:14 AM
i think the fans are ecu controlled.
doen is offline
post #13 of 27 Old May 25th, 2014, 07:22 AM
the manual says terminal 1 to ignition, terminal 2 to batt, terminal 3 to ecu(pin#14), terminal 5 to fans(+). these are for the relay.
doen is offline
post #14 of 27 Old May 25th, 2014, 07:36 AM
Pin 14 is not on the ECU inspection table. I looked in the service manual for your problem, check your water temperature switch and relays.
worthirt is offline
post #15 of 27 Old May 25th, 2014, 07:53 AM
The ECU is going to feed a voltage to the fan circuit depending on what the temp sensor and/or temp switch is sending. I can't see the schematic for that relay very well (not as big as I'd like), but it sounds as though if you put battery voltage positive to pin 1 and negative to pin 2, you will be able to get continuity between terminals 3 and 5.
Edit: I was looking at the relay that was in the wiring diagram that you linked, it is the wrong relay. It looks like the same pin out, but I am standing by my disclaimer. If I can't see the actual schematic for the relay itself, I can't guarantee that I'm correct when I tell you what pin does what!
worthirt is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
