Hey guys I'm new to the group. I got my hands on a very clean, very low mile b13 sedan with a ga16de. Was curious what you guys have found for performance parts for the 1.6 and some input on if it's worth building.
"Worth" is subjective. If you are looking for all out performance, the SR20 engines are the way to go without getting insane. They come in NA and turbo versions and the SR20DE was available in the B13 SE-R, so you know it fits. But, of course that involves harness adaptation, ECM, getting the transmission and shafts, etc. That said, you can get "reasonable" performance out of the GA16DE if you don't mind sinking a little money and effort into it.
Money & Effort are my middle names! Hahaha
(seriously though i also have a GA16DE B13 & I’ve decided I’m not doing a swap till this motor is Dead. This has been super helpful !)
Well I honestly wouldn't mind squeezing the ga16de for what it has. I know the sr does fit but like you said ecm swap and transmission. Also I'd like to not hop on that band wagon just yet. My 1.6 in the car has alot of life left. It just hit 84 thousand original miles, on the motor chassis and trans
Then keep it STOCK OEM...RUN PLUGS AND SYNTHETIC OIL AS WELL AS A FREE BREATHING AIR FILTER to give you that "EDGE" IT IS A VERY RELIABLE ENGINE BROTHER!!!
Theres way to many things you can do to the ga16de such as sr20 ecu, maf, tb and injectors. high comp pistons deom a d16 honda engine at 80 mm or .040 intake headers, i have one my self and ill be smoking sr20 engines all day
Thanks buddy, ecu close to dying.. i have a spare sr20 ecu, just clearing up things like if i can use it.. thanks again
Related Threads
Nissan Forum
1.4M posts
175.8K members
Since 2002
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
