Brake lights won't turn OFF - Nissan Forum
post #1 of 6 Old Aug 28th, 2015, 12:27 PM Thread Starter
Title says it all. Recently replaced a dead battery after being away for a couple weeks. Figured the battery finally gave out (bought Jan. 2012), but now I've found that my back lights won't turn off. I've been unplugging my battery to save it, but if anyone could help me solve this issue I would be greatly appreciative!
As my name indicates, this is on a 1994 Sentra SE.
I'll continue looking through previous posts, but at this point I have not found a similar one. Thanks.
94NissanSentraSE is offline
post #2 of 6 Old Aug 28th, 2015, 12:48 PM Thread Starter
UPDATE: Alright, it appears to be the brake light bumper. (Helpful video: https://www.youtube.com/watch?v=VH59bE0yTpY)
If this happens to you, look on the floor of the drivers side to see if any broken pieces of plastic are present. That is mostly likely the remnants of said bumper. Apparently they're pretty easy to fix!
Also, I found this source helpful regarding installation (http://www.justanswer.com/nissan/14l...-turn-off.html).
post #3 of 6 Old Jan 4th, 2018, 07:24 PM
Registered User
I have a 2013 Nissan Rogue. My brake lights stay on after I stop my car. I pull the brake light fuse and put it back in and the problem is corrected . . . until the next time. I never know when this will happen so now check to see if the lights are on before leaving my car.
Today, brake lights were on. Did my little routine of pulling fuse. All ok and then while driving a warning light c ame on indicating my anti-swerve (this has a name "Vehicle" something) was not working and then my cruise control "Set" came on and was flashing.
Help....It's not my Brake Light Bumper. I already took car into dealer.
kmilano is offline
post #4 of 6 Old Jan 4th, 2018, 10:10 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
It sounds like the brake light switch at the top of the pedal is either sticking or needs to be adjusted. The VDC (vehicle dynamic control system) and the cruise control both use the brake switch as in input, so it's understandable that the warning lights are coming on either because you keep pulling the fuse or because the switch may be sticking or in need of adjustment.
smj999smj is offline
post #5 of 6 Old Mar 23rd, 2018, 02:27 PM
Registered User
I have been fighting this problem for a month. Brake lights stay on intermittently. It causes the car to not accelerate; dangerous. After replacing the plugs and throttle body (about $500) I had someone at the Nissan dealership tell me to try the brake light switch. Then replaced the cruise control cutout switch. Finally replaced the brake light relay and so far it appears to have solved the problem.
Hope this saves someone the same frustration I have had!
BTW, this does not throw a code for this problem.
For this and other reasons, (rattletraps) I will not be owning another Nissan!!
pgood29 is offline
post #6 of 6 Old Jun 12th, 2019, 01:05 AM
Registered User
I believe multiple issues come from the same brake light switch issue. 2015 Nissan Juke does not accelerate properly, does not start properly, and brake lights remain on. I already replaced the brake light switch under the dash a year ago and now I am experiencing more issues. When take the switch off and replace it the lights on rear of car will reset. It does not start until you unplug and plug it back in multi times. This should be a recall! Nissan dealers know the problem. What a joke.
JGjg is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Brake Lights won't turn off vandermast U13 1993-1997 Altima 18 Sep 29th, 2016 12:22 PM
Brake lights won't turn off when car is off z4life Z32 Chassis 300ZX 2 Mar 24th, 2011 02:58 AM
1992 Nissan Stanza - Seatbelt/CEL/Brake Lights on Dash Won't Turn Off Mahalaleel General Altima/Stanza discussion 0 Jan 10th, 2011 07:43 PM
Maxima 87 brake lights won't turn off after engine off AwesomeMaxima87 General Maxima Discussion 2 Aug 15th, 2009 03:44 PM
Tail Lights -- won't turn off, please help. red1990 Pathfinder 4 Oct 10th, 2007 08:07 PM
You may post new threads
You may post replies
BB code is On
