Possible head issue? - Nissan Forum
post #1 of 5 Old Yesterday, 03:55 PM Thread Starter
I have a 1988 Nissan Sentra with the 1.6L throttle body injected straight 4. I have rebuilt the motor, and have since come into contact with plenty of small things going wrong. About six months ago, the head gasket blew while I was driving it and I had the head machined to work right again. It has since always misfired the first couple rotations when I start it cold, which I assumed was because it was cold. Without warning it wouldn't start about a month ago and I replaced the coil and it started up perfectly. All of a sudden about a week ago the same symptom popped up and it won't start. Found some coolant in one of the cylinders so I pulled the head off. The head gasket is in perfect shape, but every cylinder has coolant inside, with 1 and 4 being the worst. Though I haven't seen any coolant in the oil, and the gasket is fine, I'm not sure what the cause of this issue is. When I pulled the head gasket off though, I noticed that quite a few of the holes for coolant ports had been blocked off. It looks as though it came like that from the factory, but I can't totally tell. Any ideas as to what might be going on?
jvolz is offline
post #2 of 5 Old Yesterday, 11:34 PM
Sup Mod keeping the peace
rogoman's Avatar
Perform a compression test on all cylinders. The specs are: standard - 192 psi, minimum - 164 psi, Maximum Variation Between Cylinders - 14 psi. If you've got some bad cylinders, follow up with a leak-down test to determine the cause.
KA-T for life, yo!
rogoman is offline
post #3 of 5 Old Today, 12:33 AM
NF Mod/Nissan Master Tech
smj999smj's Avatar
Rogo.... How's he going to do a compression test when he pulled the head off of it, already?
Jvolz.... It's been a long time since I've even looked at an E-series in person (even though I have a B11 sitting in my front yard...slowly disappearing under years worth of pine needles). It's odd to have coolant in all of the cylinders. Can I assume you checked the deck of the cylinder head and the top of the block with a straight edge and feeler gauge? The only other thing I can think of is somehow coolant was getting into the intake manifold and getting sucked into each cylinder. I have run into a couple of porous intake manifolds on E-motors, but not in a case where it was leaking coolant. Ideally, it would have been a good idea to pressurize the cooling system before the head was removed to try and locate the leaks, but it's a little too late for that. Maybe a crack in the manifold between the intake coolant passage and an intake runner? But, I'm just guessing at this point!
smj999smj is offline
post #4 of 5 Old Today, 10:28 AM Thread Starter
I’m curious though, when we pulled the head off, the head gasket that was on there was blocking a handful of the coolant ports from the head to the block. Is that normal or is that something that the gasket maker messed up??
jvolz is offline
post #5 of 5 Old Today, 02:25 PM
rogoman's Avatar
OH OH my bad. I guess I didn't read his post accurately. That's what happens when I'm up late into the night. But at least he's got some specs that may be useful for him.
KA-T for life, yo!
rogoman is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B11/B12/KN13 82-90 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
