2010 Maxima Overcharging Problem - Nissan Forum
post #1 of 4 Old Jan 11th, 2019, 04:40 PM Thread Starter
Hello everyone,
My 2010 Maxima recently developed an overcharging problem that has been quite the gremlin. It is overcharging at about 15-15.2v, sometimes fluctuating between 14.5-15.2v. I have replaced the alternator with a Denso one, I have checked and cleaned the ground wire to chassis and tranny. I've checked the fusible link at the top of the power cable. Still the exact same issue, been searching around but haven't found anything quite like my problem. Any ideas?
remix919 is offline
post #2 of 4 Old Jan 12th, 2019, 07:50 AM Thread Starter
Forgot to also mention I replaced the battery as well, used a walmart value battery of the same size and specs.
remix919 is offline
post #3 of 4 Old May 21st, 2019, 09:58 AM
I Live Here
IanH's Avatar
Any update ?
I would record voltage at different loads.
If this shows a higher that expeted lead resistance replace the ground and power cables.
2018 Pathfinder SL with midnight pkg.
2003 Pathfinder from 2004 SE 4WD, 1June2018 Transmission expired in Temple, TX
1997 SER 5sp Manual from new Rear Ended 2009 !! Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!! Gone 2016 from Hail damage.
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline
post #4 of 4 Old May 22nd, 2019, 03:29 AM
Sup Mod keeping the peace
rogoman's Avatar
Originally Posted by remix919 View Post
Hello everyone,
There could be a problem with the "Power generation variable voltage control system". The later-model cars have adopted what Nissan calls “power generation voltage variable controls.” This system monitors battery current and varies voltage to the regulator, reducing the load on the engine and resulting in better gas mileage. By varying the voltage to the alternator, engine load due to power generation of the alternator is reduced and fuel consumption is decreased. The battery current sensor is installed on the battery cable at the negative terminal. The battery current sensor detects the charging/discharging current of the battery and sends a voltage signal to the ECM according to the current value detected.
KA-T for life, yo!
rogoman is offline
  Nissan Forum > Maxima > 2009+ Chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
2010 Nissan 370Z NISMO With Enkei Racing Wheels – SEMA 2010 djkrome Nissan 370Z 0 Oct 28th, 2010 10:45 AM
Fans Check out 2010 Nissan Maxima at Ohio State vs USC Game NissanNews General Discussion 1 Oct 4th, 2009 10:47 AM
Alternator overcharging, replaced, still overcharging cwienands B15 2000-2006 1 May 22nd, 2009 01:43 PM
2010 Nissan Maxima Diesel Coming The Only Way We'd Buy It: Stick Shift dascrow Nissan News 0 Jun 16th, 2008 09:27 AM
overcharging troubles , please help beateraltima U13 1993-1997 Altima 8 May 5th, 2006 03:13 PM
You may post new threads
You may post replies
BB code is On
