Engine code P0101 maf - Nissan Forum
post #1 of 6 Old Oct 11th, 2018, 05:09 PM Thread Starter
After replacing mass air flow sensor, light came back. Went back and read codes but this time P0101 is back plus reprogram ECM. can there be something else besides that?
Damayor42 is offline
post #2 of 6 Old Oct 11th, 2018, 07:13 PM
Sup Mod keeping the peace
rogoman's Avatar
Please state the year, model, engine, transmission of your vehicle. Detail your original problem along with any tests you performed.
I'll jump ahead and indicate possible causes for a P0101 fault code before you reply to this post.
Possible causes:
● Harness or connectors (The sensor circuit is open or shorted). A high voltage from the sensor is sent to the ECU under light load driving conditions.
● Mass air flow sensor is defective.
KA-T for life, yo!
rogoman is offline
post #3 of 6 Old Oct 12th, 2018, 06:58 AM Thread Starter
2013 Altima 2.5 SV. Original problem said P0101. I replaced maf sensor. Light went away for about 2 weeks. Light back on now this. Maf and reprogram ECM
Click image for larger version
post #4 of 6 Old Feb 11th, 2019, 10:36 AM
Did you get your issue fixed? Having the same issue.
Thanks
lmd2018 is offline
post #5 of 6 Old Jul 4th, 2019, 05:48 PM
My 2016 Nissan Altima did the same exact same with the p101 mass air flow sensor there's a service bulletin out on it at the dealership not a recall but a service bulletins and they fix mine for free they had to reprogram the ECM
Darren Bracey is offline
post #6 of 6 Old Jul 4th, 2019, 09:09 PM
rogoman's Avatar
Here's some other possible causes that you can check out:
• Intake air leaks. The best way to check the intake system for a vacuum leak is to attach a vacuum gauge to a full vacuum source. With the engine fully warmed up, the reading at idle should be 18 - 20 InHg. At 3,000 RPM, it should be 21 InHg. If readings are under 18 InHg, check the intake manifold nuts to make sure they are tight. The gasket may have failed; spray a water mist at the gasket to see if the gauge reading changes. Also check the intake plenum bellows at the throttle valve and at the MAF for cracks or loose clamps.
• Defective EVAP control system pressure sensor. For diagnostic procedure testing, reference the FSM.
• Defective intake air temperature sensor. For diagnostic procedure testing, reference the FSM.
Diagnostic procedures are documented in the FSM for your vehicle. You can download a copy of the FSM from this web site: https://ownersmanuals2.com/. Section EC.PDF is the one you need to read.
KA-T for life, yo!
rogoman is offline
  Nissan Forum > Altima/Stanza > 2007+ Altima
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
2011 Frontier P0101 MAF Code Won't Go Away 451stroker D40 2004-present 8 Oct 22nd, 2017 04:07 PM
P0101 Code Omer611 B16 2007+ 1 Feb 17th, 2017 09:07 AM
GA16 MAF vs sr20 MAF vs ??? MAF B13dude GA16DE 1.6L Engine 2 Oct 11th, 2007 08:15 PM
CEL came on: Engine code/error code/computer code- Please help Uni GA16DE 1.6L Engine 3 Mar 21st, 2005 06:42 AM
Maf Or No Maf BIGBALLER GA16DE 1.6L Engine 14 Jan 13th, 2003 10:58 AM
You may post new threads
You may post replies
BB code is On
