Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Sep 12th, 2004, 12:47 PM   #1 (permalink)
joez
90 na fuel problem?
i have a 90 na with 151k. one cylinder wasnt getting fuel so i bought new injectors, prior to replacing an injector, i ran a ton of fuel injector cleaner through the car. it fixed the problem so i didnt replace the injector, it ran great for a few months, now it started acting up again, every once in a while it drops down to 500 rpms at idle and it will bogg down like it has a heavy load when driving. it doesnt do this all of the time and it acts completely different than when i thought i had a bad injector, what do you think it is? thanks for the help
joez is offline   Reply With Quote
Old Sep 12th, 2004, 03:35 PM   #2 (permalink)
flipend47
Send a message via AIM to flipend47
you said it's acting completely different from when you thought you had a bad injector? i'd say you are probably running rich. the bogging down and low revs at iddle would make me think that - maybe your ecu hasn't adjusted tot the new injectors or somthing... are you sure you got the right ones??
just my .o2
-flip
Some people like to play cards, watch tv, or build cute little model airplanes... Me? i just like to go fast.
flipend47 is offline   Reply With Quote
Old Sep 12th, 2004, 10:22 PM   #3 (permalink)
joez
i didnt change the injectors, the problem stopped so i left it alone. now it acts funny again but is really inconsistant
Old Sep 13th, 2004, 12:58 PM   #4 (permalink)
'85 fairlady
I got a new engine!!!
'85 fairlady's Avatar
Send a message via AIM to '85 fairlady
exactly how much fuel injector cleaner did you put in??? Look at some of your sensors like the MAF.
a couple of suprises!!!
'85 fairlady is offline   Reply With Quote
Old Sep 13th, 2004, 01:01 PM   #5 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Z32 injectors are a fickle creature. I have seen and experance some injectors go bad then come back to life the next time you start up the Z. I also seem them take a dump and never come back. I think you need to replace your injector.
I would first get a OHM reader and pull off the connector to the injector in question. Then read the injector with a ohm reader (12-14 ohm) if it's over or under you need to change it.
Spongerider is offline   Reply With Quote
Old Sep 14th, 2004, 01:32 PM   #6 (permalink)
joez
ill do that, also do you think it could be a fuel filter? just today i had to start my car twice, it didnt start the first time i turned the key, one cylinder out wouldnt do that.
Old Sep 14th, 2004, 02:49 PM   #7 (permalink)
Spongerider
Power FC Z32
If you have not changed out the FF, FPR, & FPD on your Z, I would do it?
97 4cyl pickup engine cutout problem - help! Capncavedan Truck & SUV 81 Oct 21st, 2007 10:39 PM
Problem! motor turns but doesn't start SonsofWisdom S13 240SX 1989-1994 18 Dec 6th, 2005 08:45 PM
Fuel Gauge and ABS Light aaronford Truck & SUV 0 May 19th, 2004 03:34 PM
'90 Pathfinder Fuel Gauge Reading Low splatt Truck & SUV 1 Sep 22nd, 2003 02:54 PM
New recall on Fuel Pump for 2002-2003 Altima PhilGood L31 2002 - 2006 7 Aug 30th, 2003 09:53 AM
