Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Apr 19th, 2004, 09:22 AM   #1 (permalink)
pinballwiz
Angry '91 300ZX clutch problem
I have a '91 300ZX that has clutch problems. The clutch assembly, flywheel and both master and slave cylinders have been replaced. After 20 minutes or so of the engine running, the clutch is inoperable. I push the clutch in, put the transmission in ANY gear, let the clutch out and nothing. Also, I can go through all five gears and reverse without pushing in the clutch. The boys at the transmission shop are stumped, as am I. Any help???
pinballwiz is offline   Reply With Quote
Old Apr 19th, 2004, 01:27 PM   #2 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
Did they put the right flywheel, disk, and pressure plate in and are they sure they put the disk in facing the right way or everything is lined up and torqued correctly? It sounds as though the disk has just enough pressure when it is cold to operate seemingly normal and when it warms up it is just slipping in between the flywheel and the pressure plate. I'm sure they hate to do it but they should pull it back apart and double check part nos., clearances, and thicknesses. It happens where a part is misboxed, incorrectly ordered, or installed improperly. Nonetheless they can't fix anything by just thinking about it.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Did my Flywheel Go or did my Clutch Go? nathanklein SR-Series Engines (DE/VE) 6 Apr 13th, 2004 09:01 AM
Clutch Problem Popkorn B11/B12/KN13 82-90 chassis 3 Apr 5th, 2004 10:42 PM
ACT or JWT clutch? aminidab GA16DE 1.6L Engine 12 Mar 19th, 2004 07:37 PM
manuel with spec v no1d B15 2000-2006 49 Mar 8th, 2004 05:44 PM
New clutch slipping at high RPM's toolapcfan B13 91-94 chassis 0 Sep 9th, 2002 09:58 AM
