Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Mar 21st, 2004, 11:45 PM   #1 (permalink)
toolsheded46and2
Send a message via AIM to toolsheded46and2
HELP!..driveshaft removal
I need help on removing the driveshaft from my z32 the bolts are off yet it still wont come off of the diff. does anyone know if theres something i can do?
toolsheded46and2 is offline   Reply With Quote
Old Mar 22nd, 2004, 01:52 AM   #2 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
I dunno, its very easy to remove a Z driveshaft. Did yiou remove the center bearing support bolts?
Mike
There can only be one Icy Hot Stunta, Don't Hate.
Master of Level 9
morepower2 is offline   Reply With Quote
Old Mar 22nd, 2004, 02:19 AM   #3 (permalink)
toolsheded46and2
Where is that located at? i just need to remove it on the diff. side to remove the rear end.
Old Mar 22nd, 2004, 12:53 PM   #4 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
You need to remove the exhaust and then the support bar under the tranny then loosen the center bearing bolts.
Spongerider is offline   Reply With Quote
Old Mar 22nd, 2004, 05:21 PM   #5 (permalink)
toolsheded46and2
Thanks for the help i got it loose all it needed was a few good hammer taps because of it being on there for 14 years.
frontier 2 piece driveshaft Burgess Truck & SUV 3 Feb 2nd, 2004 12:39 PM
driveshaft issue malaysia_boy E/CA-Series & GA16i Engines 5 Nov 3rd, 2003 10:51 PM
A/C compressor clutch removal tyrap99 New Member Forum 1 Aug 7th, 2003 09:35 PM
Butterfly valve removal |2ED-LINE B15 2000-2006 9 May 1st, 2003 05:14 PM
Gas tank removal 1989sentra1.6 B11/B12/KN13 82-90 chassis 2 Aug 25th, 2002 07:11 PM
