Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Apr 8th, 2003, 07:56 AM   #1 (permalink)
2l8iwn
Posts: n/a
Help Car idling between 1500-2000
I popped the hood and it kinda sounds if there may be a vaccum leak behind the upper intake manifold but i cant find it. Has anybody had this similar problem, i thought if its not the problem to try and replace the throttle position sensor or check the maf but i dont know where to start. Oh yea its a 91 naturally aspirated 300z. thanks all
Old Apr 8th, 2003, 12:01 PM   #2 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Where exactly is the sound coming from? Is it behide the drivers side or pass. side manifold or is it in the center? It most likely one of your small hoses poped off or cracked.
Spongerider is offline   Reply With Quote
Old Apr 10th, 2003, 10:57 AM   #3 (permalink)
2l8iwn
Posts: n/a
it is coming from the driver side in the back, i checked the hoses and dont see anything. please help
Old Apr 10th, 2003, 12:52 PM   #4 (permalink)
Spongerider
Power FC Z32
Hmm.. sounds like your vacumm brake hose or vacumm clutch hose. I replaced mine a while ago because they were old and started to crack. If that is not it then look a the AII it might be leaking there as well. Good luck.
Old Apr 10th, 2003, 01:39 PM   #5 (permalink)
MGBRaceman
Send a message via AIM to MGBRaceman
I am having a similar problem, it could be a vacuum hose, I haven't investigated it very much though. I do have a faulty Fuel Pressure Dampiner which could be the couse of the high idle, I'm not sure. We'll see when I replace the dampiner.
I am Iridium V.
MGBRaceman is offline   Reply With Quote
Old Apr 15th, 2003, 07:15 AM   #6 (permalink)
2l8iwn
Posts: n/a
hey mgbraceman, i have noticed while sittin in the car i can sometimes smell raw gas but it wasnt contstantly so i dismissed it, can you tell me more about this dampner?
Old Apr 15th, 2003, 10:57 AM   #7 (permalink)
Spongerider
Power FC Z32
If you can smell gas you should check all your fuel lines from your gas fliter on. This could mean that you have a fuel leak and may start a fire. (Very dangerous) Please check ASAP. I have had a friend lose his Z to such a thing.
Old Apr 15th, 2003, 11:13 AM   #8 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
Re: Help Car idling between 1500-2000
If its not a vacume leak, its probably the TPS.
Mike
There can only be one Icy Hot Stunta, Don't Hate.
Master of Level 9
morepower2 is offline   Reply With Quote
Old Apr 15th, 2003, 11:24 AM   #9 (permalink)
Spongerider
Power FC Z32
Re: Re: Help Car idling between 1500-2000
Mike
What Mike means in plain english is TPS = Throttle Position Sensor located next to the driver side throtle body.
Old Apr 16th, 2003, 11:39 AM   #10 (permalink)
2l8iwn
Posts: n/a
checked fuel lines and they are cool, i popped hood and didnt smell any gas, i then realized that i only smell the gas when stopped right after i fill up, well i think what is causing that is a little gas spills out after i remove the pump from the filler neck and settles in the corner of the filler area. The gas smell then filters through to the hatch area. As for the TPS how much is that going to run and if its like my mustang i HAD to get it from the dealer cause the aftermarket stuff at autozone didnt function correctly. So should i go aftermarket autozone tps or go to the dealer and how much?
Old Apr 16th, 2003, 12:29 PM   #11 (permalink)
Spongerider
Power FC Z32
You need a ohms/VOLT meter to make sure your TPS is ok. Here is how it should read.
Throttle valve fully closed: 0.4 - 0.5V
Throttle valve fully open: approx 4.0V
If not you can adjust to thoses values. Mike are thoses values right?
As for your fuel smell I never had experiance that situation and I have had my Z since day 1 in 1992. I make a through check and make sure.
Old Apr 17th, 2003, 07:29 AM   #12 (permalink)
2l8iwn
Posts: n/a
spongerider, thanks for the volt info, i got a meter and ill check it tonight, the volts should still read when the key is in the on position even though the car is not started correct.
Old Apr 17th, 2003, 10:39 AM   #13 (permalink)
Spongerider
Power FC Z32
Yes
