Brake Lights Stay On After Key Is Removed - Nissan Forum
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
post #1 of 11 Old Aug 5th, 2009, 09:13 AM Thread Starter
1994 Z32 NA Auto
Noticed yesterday that the idiot light on the dash for the lights was fading on and off. I arrived home, parked, turned off the car, and noticed that my brake lights were still on. I tried pumping the brake pedal to no avail. Pulling the fuse under the hood was the only way to turn them off. There are no lights out.
Any quick ideas? I'm not an electrician, nor do I attempt to play one on TV or otherwise, so if you're going to suggest putting a meter to this wire and to that ground then it's to the shop with it. Hopefully someone has experienced this and knows a couple quick things to check that I might be able to attempt before I march off to spend entirely way too much money to get it fixed. Thanks.
zjunkie is offline
post #2 of 11 Old Aug 5th, 2009, 12:44 PM Thread Starter
After further review, I found some small pieces of what look like some kind of green plastic button on the floor. I'm guessing this has something to do with it. Anybody familiar with this and can tell me what part that is and where it came from?
Stage VI - JWT intake, Megan SS cat back, UR aluminum pulleys, Ruff 18" chrome/staggered 278s, Sikkens custom paint with 350Z side badge on nose, Low profile custom wing on back deck.
zjunkie is offline
post #3 of 11 Old Aug 5th, 2009, 01:12 PM
ye look up at the top of the brake pedal u will see the switch to light off, prolly that green thing is to push against the switch to turn it on and off
mitsuspyder is offline
post #4 of 11 Old Aug 5th, 2009, 01:26 PM Thread Starter
That's probably it. I'll try and check it out tonight. I'm sure it'll be a pain in diaz to try and get up under there to fix it without removing the seat - which ain't gonna happen. Hopefully I'll be able to get my hands up there and screw in a bolt or duct tape something that will hit that switch.
zjunkie is offline
post #5 of 11 Old Aug 5th, 2009, 01:28 PM
well the best way u can do it is if u have a round magnet like the ones tat u put on ur fridge tat wat i use and it does the job, caus it gonna hard to get a screw up there caus there is gonna be pressure on the brake pedal
post #6 of 11 Old Jul 14th, 2011, 02:04 PM
Rubber Stoppers Fall Out Leaving Plungers Fulling Extended (Brake Lights On)
There are 2 green rubber "stoppers" on a metal plate attached to the brake peddle and 2 plungers connected to the electronic sensor for the brake lights. When the rubber stoppers fall out leaving 2 holes, the plungers think the brake peddle is pressed, leaving the brake lights on. Not sure why Nissan did not just make a solid medal plate.
*******************SOLUTION *****************************
I taped a steel box cutter across the 2 holes and it worked perfectly.
I'm 5'8" and thin, any larger than me you may have to remove the seat. It's pretty tight (crawling under the steering wheel) like most repairs with the Z32.
jkeese01 is offline
post #7 of 11 Old Oct 23rd, 2011, 06:39 PM
There are also 2 green stoppers on the Clutch for disengaging the Cruise Control and Starter. Good idea to go ahead and fix these now too.
jkeese01 is offline
post #8 of 11 Old Oct 23rd, 2011, 07:08 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
I remember using a round, plastic trim fastener (aka Xmas tree clip) like those used to attach door panels to the door one time when I was in a pinch until I got the correct part from Nissan.
smj999smj is offline
post #9 of 11 Old Oct 24th, 2011, 09:49 AM
DIY Better than Nissan Replacement?
Since the rubber Nissan parts will fail again one day, is there a reason to use it and not a more permanent DIY material?
It is a real pain to be stuck in a parking lot with a totally dead battery (could not even push start the car) because this rubber part failed and left the rear brake lights on.
jkeese01 is offline
post #10 of 11 Old Oct 24th, 2011, 12:26 PM
smj999smj's Avatar
My guess as to why they used the rubber stopper was less wear and tear on the switch plunger, but, that's only a guess. On the other hand, keep in mind your car is 17 years old and how long the original stopper lasted! It's not like you're going to be replacing it very often. But, as already suggested, I would go ahead and replace them all, because if one's bad, the others are probably not far behind!
post #11 of 11 Old Oct 24th, 2011, 05:00 PM
That's a good point. But I'm still driving my 1977 Datsun 280z, so the 1993 Nissan 300zx may still be here in another 17 years, long enough for me to have forgotten those rubber stoppers, and experience another dead battery in the parking lot.
I recently replaced the ones on the Clutch with plastic "Panel/Trim Retainers". Picked the ones with the smooth head.
jkeese01 is offline
  Nissan Forum > Nissan Z > Z32 Chassis 300ZX
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
