92 300ZX has not fire at coil - Nissan Forum
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
post #1 of 8 Old Apr 12th, 2009, 10:08 AM Thread Starter
Question 92 300ZX has not fire at coil
I have a 92 300 ZX Twin Turbo and it won't start. It used to run fine and now it won't start at all. Where can I start? My father has one too. I am thinking about swapping the square electronic device in front of the timing belt which Nissan recalled in the mid 90s for troube shooting. Please give any ideals on where I can start searching. Motor and transmission is good. please advised and thanks. James
jidebose is offline
post #2 of 8 Old Apr 12th, 2009, 07:46 PM
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
It could be the PTU but first check the fusable links located next to the battery.
Spongerider is offline
post #3 of 8 Old Apr 21st, 2009, 08:32 PM
Nissan Addict
Send a message via AIM to Outkast
PTU and/or CAS, run codes is a good place to start.
Nissan Master Tech, Mtn View Nissan Chattanooga, TN
Outkast is offline
post #4 of 8 Old Apr 23rd, 2009, 09:46 PM Thread Starter
the ecu codes that I am getting is 5 red flashes slow and 5 red flashes slow. I check the power going to the CAS. No fire still going to the spark plug. I even swap PTUs. What does this code tell me?
jidebose is offline
post #5 of 8 Old Apr 23rd, 2009, 10:16 PM
Nissan Addict
55 is no malfunction. but obviously you have one. At this point you'll need to either get a trouble tree from a service manual or OSM to dio it cause this is something that needs to be dug into.
Outkast is offline
post #6 of 8 Old Apr 24th, 2009, 09:03 AM Thread Starter
Outkast,
I typed the info below wrong. it reads 5 red flashes slow and 5 red flashes fast. This may be a stupid question, but what is a trouble tree and an OSM? I have a service manual and still reading it. Thanks for your reply.
jidebose is offline
post #7 of 8 Old Apr 24th, 2009, 11:15 AM
Nissan Addict
I asumed that cause 55 is the only 5 flash code. A trouble tree is what you can use to test individual areas to find the cause. You might chech the resistance on one componante and voltage drop of another. OSM is Online Service Manual you can download it from most sites for free. I can't remember if this site has it up but you can get it for sure from 300zxclub.com.
Outkast is offline
post #8 of 8 Old Sep 12th, 2010, 02:37 PM
can some one tell me what would cause the 5th and 6th cylinder not to fire on my 93 300zx yes ive done all the required maintenance, ie ohm checks ptu, ejecters,coils spark plug all check out
nissan reg is offline
  Nissan Forum > Nissan Z > Z32 Chassis 300ZX
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
