Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Jan 10th, 2008, 04:21 PM   #1 (permalink)
z7z1z0
1990 300ZX Heat Problems
Originally Posted by 2001GLE View Post
No, I had a digital climate controlled 1990 n/a 2 seater. They are totally different systems. Seriously be glad u have the sliders over digital. The digital became a nightmare for me. The a/c stopped working. Wasn't the compressor or level of freon. It was the motors inside the dash that actuate the temperature. VERY expensive. $500 just to get into the dash, not even parts.
This exact thing happened to me recently with my 1990 300zx 2 seater, the motors inside the dash will not work anymore and I can't get it to change to heat, it simply blows out cold air all the time no matter what settings I put it on. I took it to Nissan and they simply turned the motors or vents in the direction needed for heat and charged me around $400 just to change some corroded plugs and not replace anything in the heat, just get it blowing out hot air.
Well I was messing with the temp gauge and I switched it to ac and now when I switch back to heat, the motors stay on AC so I am left with the same damn problem again.
Is there anyway to temporarily move the vents back again to the heat position? Is it so hard you can't do it yourself? I am not that mechanical but I am willing to try anything.
z7z1z0 is offline   Reply With Quote
Old Jan 11th, 2008, 08:32 AM   #2 (permalink)
z7z1z0
bump bump please help!
Old Jan 11th, 2008, 11:07 AM   #3 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
"they simply turned the motors or vents in the direction needed for heat"
Could you please give me more detail? I don't understand the turned part? Also what year is your Z?
Spongerider is offline   Reply With Quote
Old Jan 11th, 2008, 10:02 PM   #4 (permalink)
z7z1z0
It is a 1990. And all I said there was that I know Nissan didn't fix the problem when I brought it in to them, I believe they simply manually adjusted the vent direction so that the hot air blew out through the front and top vents.
Old Jan 14th, 2008, 03:43 PM   #5 (permalink)
Spongerider
Power FC Z32
You probably can do it yourself. Look att he FSM?
http://www.nissanforums.com/z32-chas...32-manual.html
1990 300zx automatic transmission TVgal Z32 Chassis 300ZX 5 May 19th, 2006 09:12 PM
'84 300zx problems? cro300zx Z31 300ZX(T) 2 Jul 23rd, 2005 07:54 PM
Just bought a 1986 Nissan 300zx Non-Turbo - MANY problems - help!!! BoBakTXL Z31 300ZX(T) 10 Sep 16th, 2004 06:17 PM
What is your opinion on the value of a 2900 mile 1990 300ZX TT? mrcarnut Z32 Chassis 300ZX 9 Jul 6th, 2004 12:37 AM
