Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old May 24th, 2007, 05:32 PM   #16 (permalink)
ExileinOblivion
hey i stopped by the car today to see if there was any progress and i noticed something... i have good pressure in my pedal when the ignition is off but when i start it up i lose the pressure and the pedal feels loose... is there an electronic component that pressurises anything? i was also told that the rust that was on my pressure plate may have spread to the clutch bearing spring which would explain why it would be getting stuck on engaged and unengaged... what do you make of these developments?
ExileinOblivion is offline   Reply With Quote
Old May 24th, 2007, 05:46 PM   #17 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Originally Posted by ExileinOblivion
alright now im getting pissed, and i know its just myown fault. i need your guys' professional opinion now... should i just replce the whole friggen clutch and get it over with? like its funny cause if i was modding my car then i would expect this delay but i bought htis car because it was 100% clean and this is still happening,l i hope this isnt a prelude of whats to come... but still if replace the whole clutch is it going to fix 90% of the problems it could be aside from the bleed? like the bars and pressureplates and everything you guys were talkin about??
That is because you clutch is vacuum assisted. When the engine is off there is no vacuum.
Here are the two places to bleed from.
Blue arrow.
Red arrow.
Thank Robo for the pics!
Spongerider is offline   Reply With Quote
Clutch problem with 97 pickup tazor Frontier 4 Jul 5th, 2006 07:25 PM
1993 Nissan NX 2000, Clutch problem mcs B13 91-94 chassis 2 Jun 30th, 2006 05:31 PM
2005 Clutch Problem inyourface1650 Frontier 23 Jan 17th, 2006 03:34 PM
1998 200 SX SE-R Clutch Problem Seanroy B14 95-99 chassis 3 Nov 4th, 2005 11:00 AM
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 7 Sep 1st, 2005 11:16 PM
