» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Dec 15th, 2006, 10:04 AM   #1 (permalink)
FuerGrissa
90 TT clutch problem?
I just bought a 1990 300ZX sight unseen from halfway across the country and in order to forgoe the month it would take to get it shipped decided to fly up and drive it back home. well suprise suprise now im stuck halfway home but at least i got a brother in the area with a garage i can use. as background its a 1990 300ZX TT manual. the only things i know for sure that are done to it are new rings and rod berrings, new HKS intercoolers and some type of "Stage 3 racing clutch" as the previous owner described it. anyways it has an interesting problem that has me a bit baffled. after you have been driving the car for over an hour or two and it gets good and hot the clutch will slip sometimes, ie: i was coming up an on ramp in 3rd shifted fine, put the pedal down a bit and it started to pick up speed, but then lost all power transfer to the wheels and just revved out untill i got out of the gas and kinda babied it up to speed. when it started slipping there was no vibration, rattle, sound, smell or anything. that was the first encounter. after driving for anout hour or so i stopped to get gas, when i parked the car it was driving fine, when i came out started it up and went to pull out on the road in 1st gear it did the same thing, the clutch was fully out but it wasn't engaged all the way or something, wether i revved out the engine, or tried to baby it didnt make a difference, as far as the power getting to the wheels it might as well have had a lawn mower engine, and it was the same in every gear, same thing, no sound smell or vibration when it went out or after. anyways i pulled into a garage but they were closed so i sat there for about an hour and a half, decided to give it another go and suprising enough it worked. so i got back on the interstate and went as far as i could untill i got stuck in stop-and-go in new jersey. the car seriously does not like to go under 5 mph lol, so after riding the clutch for a good 30 minutes it went out again, i got it down and off ramp but lost all power transfer all together at the bottem and couldnt even get into a parking lot, I wated about and hour and it still wasnt cool enough to get off the road, but with a good push i was able to nurse it into a parkinglot where i waited another hour and a half before it was good to go again. long story short i made to to my brothers house in PA about halfway home and if anyone can help me diagnose the problem so i can fix it faster and cheaper id very much appreciate it.
ohh yeah, and the new "Racing Clutch" has under 1k miles on it.
*edit* on another note even though the car has given me so much problems i am infatuated with it, its everything i've dreamt of since i was 16.
FuerGrissa is offline   Reply With Quote
Old Dec 15th, 2006, 01:23 PM   #2 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
It could be a number of things but try these first since it's free.
Re-bleed your your clutch system and look for signs of leaking around the master and slave cylinder.
if that looks ok then visit this site and adjust your clutch.
Specialty-Z Clutch Pedal Adjustment
If the clutch was not broken in properly then that could be the problem as well and would need to be replaced.
Spongerider is offline   Reply With Quote
Old Feb 14th, 2007, 12:25 PM   #3 (permalink)
WILDFIREBLAZING
I 2 have had this same identical problem and nothing in the world i have done to get it fix now i have a blown head gasket so i decided to replace the old worn out engine with a jdm replacement so when i have the engine out i am going to flush the entire clutch system out and replace with new parts
i even went as far as replacing the clutch booster which still didnt solve my problemi have bled, adjusted, and new clutch so i know how u feel i the guy that i bought it from only said he had a clutch problem.
there this one thing i havent tried that the guys from z1 told me to use super blue racing fluid cause it can stand up to 500 degrees and can with stand the heat.
try this tell me what happens
WILDFIREBLAZING is offline   Reply With Quote
Old Feb 14th, 2007, 12:55 PM   #4 (permalink)
Spongerider
Power FC Z32
Changing the fuild will not help. Why would you need fuilds to with stand 500deg? Is you car stricly racing?
The clutch system is easy to figure out problems.
This is the hardware that wears out.
1) clutch master cylinder
2) slave cylinder
3) Clutch hose
4) clutch.
These are human error.
1) Bleeding procedure
2) clutch adjustment
3) improper installation.
It can not be the type of clutch fluid.
Old Feb 15th, 2007, 01:41 PM   #5 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
Might have a mild rear main seal leak. Should be somef residue around the bottom of the clutch bellhousing, though.
One thing to do might be to rebleed the clutch hydraulic system. If it has an air bubble, it will expand when exposed to engine heat for a long time and create pressure against the slave cylinder piston, forcing it out, effectively partially disengaging the clutch just as if you had actually pushed on the pedal slightly. Fluid expansion will also do this, particularly if DOT 3 and DOT 4 have been mixed together. In which case the system will need to be flushed thoroughly
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline   Reply With Quote
Old Feb 26th, 2007, 12:11 PM   #6 (permalink)
WILDFIREBLAZING
2) slave cylinder
3) Clutch hose
4) clutch.
he suggested using a higher degree fluid because its when the fluid heats up and expand that causes my problem using a higher degree fluid would or shud have help to with stand the heat cause of its higher boiling point.
everything you have listed here i have done even the nissan dealer cant get it right had 5 certified mechnics who deals with this kind os stuff 4 a living tried n fail.
Old Oct 7th, 2009, 10:44 AM   #7 (permalink)
TwistdIntentions
So myself and an acquaintance have the only 2 Z32's in our town and we both are facing the same issue. He's gone as far as replacing his tranny and even that offered no relief. Today I'm replacing the master-to-slave tubing and hose just in case it's collapsing. Spongerider's link above offered adjustment info on the switches under the dash that I have completely disregarded but now I'm gonna see what happens with that. Wish me luck. My dream car is turning into a nightmare.
TwistdIntentions is offline   Reply With Quote
Old Oct 8th, 2009, 01:07 PM   #8 (permalink)
Spongerider
Power FC Z32
It's called a labor of love. We all go through it.
Old Oct 8th, 2009, 10:02 PM   #9 (permalink)
TwistdIntentions
Talking You gotta be kidding me...
Ok. Clutch adjustment....check. Little elusive non existent rubber hose....check. Clutch slippage ..... F#%CKING check ! What the hell,man. I finally decided to talk to a local Nissan tech that's been around since before Datsun. He says there's no such thing as an ACCURATE aftermarket master cylinder. So after taking my car to the Nissan service center,waiting an hour,and paying him $50 I get back a beautifully sensitive,snatch-n-grab clutch with an O'Reilly's master cylinder still in place. What did he do? How did he solve my enigma? Dunno. Won't tell me. He only replies in his funky little German accent ... "Did my job." Fair enough.
I can offer this suggestion though. I found that when the clutch goes to slipping,almost no matter how bad
1) With the car in Neutral and running pop the hood
2) Get out
3) Open the clutch bleeder valve on the fender and close it back tightly.A small amount of fluid will squirt all over the tire well. Wipe that off.
4) Get in the car,push the clutch,put it in first,do a wicked burn-out as you leave the parking lot.
Not so much a good thing,but it got me outta traffic. Usually had to do that every 40 minutes or so. By the way...brake fluid eats paint.
Old Oct 9th, 2009, 05:04 PM   #10 (permalink)
Spongerider
Power FC Z32
With a $50.00 bill all they did was bleed the system. Did you have another person help bleed your clutch? Also did you bleed top, then bottom, then top , and then bottom in that order?
It sucks the old guy did not tell you how he fixed it.
Old Oct 9th, 2009, 05:34 PM   #11 (permalink)
TwistdIntentions
Nope. Some kind of adjustment. All i know.
Old Oct 30th, 2009, 01:51 PM   #12 (permalink)
RJPKRP
Bleed procedure
"You’ll need a friend to help you."
I believe in Christianity as I believe that the sun has risen: not only because I see it, but because by it I see everything else. -C. S. Lewis
RJPKRP is offline   Reply With Quote
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 13 Oct 5th, 2009 09:31 AM
Clutch problem with 97 pickup tazor Frontier 4 Jul 5th, 2006 08:25 PM
1993 Nissan NX 2000, Clutch problem mcs B13 91-94 chassis 2 Jun 30th, 2006 06:31 PM
2005 Clutch Problem inyourface1650 Frontier 23 Jan 17th, 2006 04:34 PM
1998 200 SX SE-R Clutch Problem Seanroy B14 95-99 chassis 3 Nov 4th, 2005 12:00 PM
