Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Dec 21st, 2006, 06:30 PM   #16 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Originally Posted by Z_Rated
Not what I meant, sorry. I was wondering if it is even possible to tweak the timing far enough to compensate being off because I have no experience being "one adjustment off" to answer jlund's question. Z
No, this is a v6 and not a in line engine. If you are able to correct one side of the timing the other side will be off no matter what you do. This is why jlind has to make sure the timing belt matches the gears correctly.
Spongerider is offline   Reply With Quote
Old Dec 21st, 2006, 06:42 PM   #17 (permalink)
Z_Rated
Nissan Addict
That's what I thought, didn't think there was room for that much adjustment leading me to believe there are other issues at hand like bad connections and corrosion etc. Thanks, Z
Z_Rated is online now   Reply With Quote
Faq About Sr20ve LIUSPEED SR-Series Engines (DE/VE) 34 Feb 14th, 2008 01:21 PM
Hanging rpm Tricked GA16DE 1.6L Engine 11 Oct 30th, 2006 07:20 AM
car jerkin at certain rpm kaotek Truck & SUV 6 Oct 1st, 2006 01:23 AM
rpm fluctuates calvinhobbes U13 1993-1997 Altima 3 Feb 6th, 2005 09:05 AM
low rpm 2000se2.0 B15 2000-2006 6 May 6th, 2003 05:28 AM
