Red Dash Light Help? - Nissan Forum
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
post #1 of 9 Old Nov 26th, 2006, 08:16 PM Thread Starter
So today my friend laid in my trunk and after that i have a red light on the dash what could it be. i attached a pic of the light
Sim0nsays21 is offline
post #2 of 9 Old Nov 27th, 2006, 12:40 PM
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Check your brake lights? Also if you replaced your bulb with non OEM one that light will appear. OEM bulbs use a different wattage and why the warning light come on.
Spongerider is offline
post #3 of 9 Old Jan 29th, 2007, 02:38 PM
i have the same problem on my 1994 300zx it just comes on when i hit the brakes i checked the bulbs and they are th oem bulbs and the lights still come on so i took a piece of black tape and covered the warning light up seems to work really good lol
nac300zx is offline
post #4 of 9 Old Jan 29th, 2007, 02:44 PM
Power FC Z32
It's your brake lights. You should go a replace them with new OEM brake lights that you buy from the Nissan dealer not Pep boys. This will solve your problem.
post #5 of 9 Old Jan 30th, 2007, 01:19 AM
Send a message via Yahoo to js9krcr01040
And also please use the search function. This topic has been discussed numerous times.
1992 300ZX TT Stage Alot- 463.9 RWHP/551.2 RWTQ More coming soon :)
1997 240SX SE- Semi-stock for the time being :)
js9krcr01040 is offline
post #6 of 9 Old Feb 5th, 2007, 10:57 AM
have the same problem , as I replaced with aftermarket lamps from pep boys , don't
want to see that red light in the dash..... so I cut the wire in the back , put a tape so ..........it can be connected anytime , just in case I want to see it again
fscruzee
fscruzee is offline
post #7 of 9 Old Feb 5th, 2007, 12:27 PM
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
A warning light generally means that something is wrong that needs to be fixed. If you are going to cover or disconnect one warning light you might as well just cover every warning light in your dash and run the car til it dies. I mean seriously, do you people not care about keeping your vehicles in good running order? If I cared enough to post on a message board about it, I'd probably care enough to try to fix it right.
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline
post #8 of 9 Old Feb 5th, 2007, 12:29 PM
I Live Here
Zen31ZR's Avatar
It was probably replaced with the incorrect bulb or an LED bulb which will also set off the warning light (voltage draw too low). These are pretty common mistakes.
Zen31ZR is offline
post #9 of 9 Old Feb 6th, 2007, 11:37 AM
Power FC Z32
Agreed!
  Nissan Forum > Nissan Z > Z32 Chassis 300ZX
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
95 Maxima Brake Light on Dash bbpatt A32 1995-1999 Chassis 3 Jan 14th, 2007 07:53 PM
Dash Light Help Frank1 Pathfinder 0 Feb 3rd, 2006 05:19 PM
Red Light Cameras god (i suck) Off Topic 5 Dec 10th, 2005 06:29 AM
Dash Light Replacement SpongeBob-RC B13 91-94 chassis 9 Apr 30th, 2004 10:21 PM
Red Head Light coming on tarzan052566 B11/B12/KN13 82-90 chassis 7 Oct 20th, 2002 09:27 PM
You may post new threads
You may post replies
BB code is On
