Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Feb 9th, 2006, 06:16 PM   #1 (permalink)
fifty$240
Rough Engine
I just bought a '91 300zx TT and love it. only 59,000 miles.
Anyway. there are two problems I have. One the Boost guage does not work and sometimes the engin feels as if it has one bad cylinder (not firing). then after a while the engine runs perfect.
Since this is my first Turboed car i do not know what it might be. I am mechanicaly savy, but just don't want to take the engine apart to find the problem. If anyone has any ideas, please share them. Thanks
fifty$240 is offline   Reply With Quote
Old Feb 9th, 2006, 06:28 PM   #2 (permalink)
Outkast
Send a message via AIM to Outkast Send a message via Yahoo to Outkast
Check the coils and plugs for spark for the second question and as for the boost gauge I'm at a lose on that one. If it's like an aftermarket one check all the vacuum lines. Cause I have never seen that problem
(¯`·._--={ONE AMAZING Z GALLERY}=--_.·`¯)
Twin Turbo Z
Outkast is offline   Reply With Quote
Old Feb 9th, 2006, 06:55 PM   #3 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
If it's a intermittent problem it could be a number of thing, loose connection and or fuel injector on it's way out.
Are you using a stock boost gauge or a aftermarket? When you say it does not work does it not move at all?
Spongerider is offline   Reply With Quote
Old Feb 10th, 2006, 10:48 AM   #4 (permalink)
Big-Reese
Send a message via Yahoo to Big-Reese
I agree with outkast. But if it is an aftermarket one it could be crap since some times when you buy things new they still dont work. Also you could have wired it wrong. Check the wiring and vacuum lines and all that crap.
Big-Reese is offline   Reply With Quote
Old Feb 10th, 2006, 07:07 PM   #5 (permalink)
fifty$240
Thanks all for the input. it is a stock boost guage. When I turn the car on it goes from the Left to center (-14 psi to 0 psi). and then it stays there.
Old Feb 10th, 2006, 10:24 PM   #6 (permalink)
Big-Reese
The needle doesnt move from there? If thats the case I think Im not for sure but I think its your vaccum lines.
Old Feb 11th, 2006, 09:41 PM   #7 (permalink)
fifty$240
I fixed the boost guage. It was a cracked and disconected vacum line to the sensor. I cut the hardend part, spliced in some new hose and hooked it up the sensor. Works great, I Love to see my boost guage work. Lets me know that my turbos are working. I LOVE IT!!!!.
As for the Rough Engine, It is acting normal but once in a blue moon ( usualy after acceleration) it goes back to rough for about a minute and then goes back. I Checked to see if the coil pack connectors were loose and they were ok. Any ideas??
Thanks for the responses so far. I like the input.
Luis
Old Feb 12th, 2006, 01:13 PM   #8 (permalink)
Big-Reese
it could be alot of things your timing might be off just alittle bit. Your belt could be bad or your pulleys could be bad as well. If it does it after acceleration and then your rpm drop down and it is rough for a min sounds like maybe you pulleys or something.
Old Feb 12th, 2006, 07:43 PM   #9 (permalink)
mgh
Your rough engine idle sounds like a injector going bad or a bad or corroded connector. These engines are bad at having corroded connectors.
If you know someone that has a ConZult program, this will show engine and sensor fuctions.
If you haven't done the 60K maintenance yet, don't put it off passed 60K. Timing belt break = lunched motor.
mgh is offline   Reply With Quote
VQ35DE in a S13??? toddk S13 240SX 1989-1994 68 Dec 31st, 2007 10:55 PM
92 Stanza, engine rpm revs and falls rt76 Stanza 4 Sep 13th, 2005 01:40 PM
Engine Problems - Help with Diagnosis JPGva L31 2002 - 2006 5 Jul 22nd, 2005 04:03 PM
'04 Xtera Engine Seized Alan DeForest Truck & SUV 12 Jul 10th, 2005 06:07 PM
Converting a VG30 engine to Fuel Injection MrBadExample Truck & SUV 1 May 15th, 2004 10:17 AM
