Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Jan 31st, 2006, 10:50 PM   #1 (permalink)
Zwannabe
clicking noise help
I have finally purchaced a 1991 300zx TT w/ a 5 speed and can't wait to drive it but have found a small problem. I have noticed that when I drive the car there is this constant clicking sound that speeds up as I go faster. I'm thinking that it is the lifters but not really sure. I have also noticed an oil leak. Would that be the oil pan leaking?
Zwannabe is offline   Reply With Quote
Old Feb 1st, 2006, 09:21 PM   #2 (permalink)
Blanco 300Z
Blanco 300Z's Avatar
my possible diagnosis. maybe even correct....
1. "speeds up as i go faster" not rpms but vehicle speed..... transmission, possible thouhghout berring or clutch related.
2. oil leak.... welp, depends on where it is coming from. my 91 Z had the front main seal (crank seal) replaced in '02 and now the lil basterd is leaking again. but it is only like a half a quart per oil change (3000 miles) it may be common for the nissan v6. the nissan 4 banger leaks from the rear main or timing cover and v6 usually front main. ( i work on a lot of cars, like 65 per day(manager of a quicklube www.vioc.com))
3 good luck with your new toy (BTW nissan 300zx......high cost, high maintenance)
laters !!
'90 Z32 TT 5spd Project car...
http://www.cardomain.com/ride/3013106
Blanco 300Z is offline   Reply With Quote
Just Changed Front Brakes and getting a clicking noise harnold007 Suspension & Brakes 2 Sep 25th, 2005 10:09 PM
Clicking noise on a sharp turn 93altima U13 1993-1997 Altima 5 Aug 18th, 2005 09:17 PM
clicking noise doriftoboy S13 240SX 1989-1994 20 Mar 8th, 2005 09:05 PM
Engine Clicking Noise Gerardo S14 240SX 1995-1998 15 Mar 1st, 2005 03:26 AM
02 Type R Clicking noise dasilvaspecV B15 2000-2006 9 Jun 24th, 2004 07:08 PM
