Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z32 Chassis 300ZX
Z32 Chassis 300ZX 1990-1996 300ZX Z32 Chassis Discussion
Old Jan 4th, 2006, 09:44 PM   #1 (permalink)
WILDFIREBLAZING
Air noise when clutch is engage
Ok after all the work changing the clutch putting it back together i know find another problem when i engage the clutch i hear lots of air sounds wooshing from under the dash board. but when i let up off the clutch it goes away until i press it again is this normal or cud it b my problem
I am still having problems with the clutch after like 30-45 mins of driving it slips so i havent done much driving seeing that its a new clutch
I have done the bleeding change master n slave the clutch pedal been adjusted what else is there to do
WILDFIREBLAZING is offline   Reply With Quote
Old Jan 4th, 2006, 11:50 PM   #2 (permalink)
Spongerider
Power FC Z32
Spongerider's Avatar
Send a message via AIM to Spongerider
Check and make sure that the vacume hoses are not leaking from the clutch booster.
Spongerider is offline   Reply With Quote
Old Jan 5th, 2006, 11:07 AM   #3 (permalink)
zx300
check master cylinder & booster..
NISSAN
DATSUN
zx300 is offline   Reply With Quote
Old Jan 18th, 2006, 01:42 PM   #4 (permalink)
WILDFIREBLAZING
The mechenic says that the diaphram in the clutch booster is bad cud this be the culprit to all my problems
also where can i check to purchase 1
Old Mar 10th, 2006, 06:57 PM   #5 (permalink)
WILDFIREBLAZING
Ok its been a while n the car has been laid up 4 a month I finally got the booster changed which required the whole dam dash to be striped.
Here is what the car is doing after about half hour of driving it still slips then it reaches the point where the car cant move. take in mind i have not adjusted the pedals (yet) and also am installing a stainless steel clutch line
I know that the booster was my problem cause when it came out it had a screw size hole in it where sum 1 tried to drill thru the fire wall
Does any 1 think that my tranny cud be gone or with enough adjusting it should be fixed.
Wat r the syntoms of a bad tranny
ticking noise behind inlet manifold. 96 200sx. + clutch gone :( cookci General 240SX/Silvia/S12 200SX 1 Oct 3rd, 2005 03:28 PM
gas mileage down 3mpg...could it be the MAS? svasica B15 2000-2006 16 Nov 8th, 2004 08:21 PM
Clicking noise near clutch pedal? SERialThreatz SR-Series Engines (DE/VE) 4 Mar 21st, 2004 06:01 PM
Can't Tighten Clutch Cable Any More large168 B14 95-99 chassis 13 Sep 5th, 2003 10:51 AM
93 SE-R, rough...snapping clutch cable dr_shmass B13 91-94 chassis 4 Jun 27th, 2002 10:15 PM
