Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Nissan Z > Z31 300ZX(T)
Z31 300ZX(T) 1984-1989 Zs - Engine and Chassis Discussion
Old Feb 25th, 2005, 02:24 PM   #1 (permalink)
ICP Sux0rZ!
Vanilla Ice all the way baby!
ICP Sux0rZ!'s Avatar
Send a message via AIM to ICP Sux0rZ! Send a message via Yahoo to ICP Sux0rZ!
light sensor problem
so on wednesday i put in my new foglamp bulbs, and now my little warning light in my digidash is saying my rear lights are blown, and they aren't, any ideas on how to fix this?
1987 300Zx Pic 1
1970 Custom VW roadster Pic 1 Pic 2 Pic 3
ICP Sux0rZ! is offline   Reply With Quote
Old Mar 1st, 2005, 05:09 PM   #2 (permalink)
ICP Sux0rZ!
bump, ok so i did have one light out, and i fixed it, and the sensor is still saying i ahve a rear light out, i took all the lights out of the housings, and tested them and i ahve no blown lights, is my sensor dead?
1987 300Zx Pic 1
Old Mar 1st, 2005, 06:07 PM   #3 (permalink)
Domdogg123
Send a message via AIM to Domdogg123
I believe you just answered your own question.
Domdogg123 is offline   Reply With Quote
Old Mar 1st, 2005, 06:14 PM   #4 (permalink)
ICP Sux0rZ!
sensors dead?
1987 300Zx Pic 1
Old Mar 1st, 2005, 11:00 PM   #5 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
You must have preempted voltage from a source the rear light sensor used to determine bulb functionality. Undo what you did and the problem may be fixed.
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline   Reply With Quote
Old Mar 1st, 2005, 11:10 PM   #6 (permalink)
ICP Sux0rZ!
all i did was replace a burnt out bulb with the correct size and voltage replacement
1987 300Zx Pic 1
Old Mar 2nd, 2005, 12:42 AM   #7 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
No, when you installed your fog lights. Something happened when you replaced those. Maybe knocked something loose or caused a ground fault.
Old Mar 2nd, 2005, 12:52 AM   #8 (permalink)
ICP Sux0rZ!
no i cleaned all the connectors, i actaully reconnected a disconnected ground wire. i think its something completly seperate, i think its jsut a concidence
1987 300Zx Pic 1
Old Mar 2nd, 2005, 01:01 AM   #9 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
I suppose. However, when you've been working on cars as long as I have, you began to realize there's no such thing as a coincidence......
Old Mar 2nd, 2005, 02:09 AM   #10 (permalink)
ICP Sux0rZ!
i seriously think its just a coincidence, all the bulbs are OEM factory specs
1987 300Zx Pic 1
Old Mar 3rd, 2005, 12:12 PM   #11 (permalink)
ICP Sux0rZ!
i found out what the problem is, i installed LED bulbs and the sensor doesnt like them, so i jacked some 1157's from a 240sx we ahve at class that we use for parts, any idea on how to make the sensor liek them, or could i use the silverstar 1157's
1987 300Zx Pic 1
Old Mar 3rd, 2005, 09:42 PM   #12 (permalink)
asleepz
13 PSI and lovin it
asleepz's Avatar
The LED bulbs aren't going to work..
The sensor works like this
It measures the voltage coming through the bulb. Your LED light bulbs have resistors in that bring the 12VDC down to something around 3-6. It sees the voltage drop. It says you have a light out..
1987 300ZX Turbo, 5 Speed, TurboXS H-34 BOV, WAI,
Under Construction
Clutch, Wheels, Tint, Paint, Interior, HID
asleepz is offline   Reply With Quote
Old Mar 3rd, 2005, 10:37 PM   #13 (permalink)
ICP Sux0rZ!
hence why im bypassing teh sensor
1987 300Zx Pic 1
Old Mar 4th, 2005, 02:57 PM   #14 (permalink)
asleepz
13 PSI and lovin it
asleepz's Avatar
good luck....
Under Construction
Old Mar 4th, 2005, 04:14 PM   #15 (permalink)
ICP Sux0rZ!
hehe i figured out a rather simple shortcut to bypass the sensor.....ignore it by cutting the wire that goes to the idiot light...lol the sensor can scream at me all it wants...i won't hear it lol
1987 300Zx Pic 1
Michael's '95 Check Engine Light jadcock Truck & SUV 1 Oct 20th, 2004 12:18 PM
Instrument Panel Light Jesse Bolt General Discussion 0 May 2nd, 2004 07:44 PM
How many Nissanforums to change a light bulb? Kalel Off Topic 7 Jan 28th, 2004 06:21 AM
no brake light when tail light is on SEv6 New Member Forum 5 Nov 7th, 2003 08:43 PM
how many forum users? xt_out Off Topic 4 Aug 27th, 2003 02:02 AM
