» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Nissan Z > Z31 300ZX(T)
Z31 300ZX(T) 1984-1989 Zs - Engine and Chassis Discussion
Old Aug 9th, 2004, 03:48 AM   #1 (permalink)
♣300zx♣
♣300zx♣'s Avatar
Engine NOISE.....
Hey my 86 300, when i let of the gas pedel in gear, like 35mph lets say, i hear ticking maybe valves? It goes away as I step on gas.. what would that be?
:banhump: ♣300ZX♣ :banhump:
♣300zx♣ is offline   Reply With Quote
Old Aug 9th, 2004, 11:35 AM   #2 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
I don't think that's valves......
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline   Reply With Quote
Old Aug 13th, 2004, 08:32 PM   #3 (permalink)
RocketRodent
RocketRodent's Avatar
Send a message via AIM to RocketRodent Send a message via MSN to RocketRodent
Lifters.
RocketRodent is offline   Reply With Quote
Old Aug 13th, 2004, 08:51 PM   #4 (permalink)
'85 fairlady
I got a new engine!!!
'85 fairlady's Avatar
Send a message via AIM to '85 fairlady
lifters
a couple of suprises!!!
'85 fairlady is offline   Reply With Quote
Old Aug 13th, 2004, 09:38 PM   #5 (permalink)
Marc Z31
Nissan Fanatic
Marc Z31's Avatar
Send a message via AIM to Marc Z31
Lifters, man. Start using 20W50
...BUILT FOR THE HUMAN RACE...
Marc Z31 is offline   Reply With Quote
Old Aug 13th, 2004, 09:40 PM   #6 (permalink)
'85 fairlady
i heard that if you run 30w it suposed to clean your egine or something like that???
Old Aug 13th, 2004, 10:15 PM   #7 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Yeek no , 30W is non-detergent.
Old Aug 13th, 2004, 10:42 PM   #8 (permalink)
'85 fairlady
what would one use then?
Old Aug 14th, 2004, 10:29 AM   #9 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Theres a few schools of thought to this answer. One way I have heard of is to add a 1/4 to 1/2 a quart of auto trans fluid run it for a while and drain it. If left too long the trans fluid can affect the seals , so it's best to drain it after a few hours of running.
Another way is to use one of the oil cleaners from the autoparts store , but those in the know don't care for that approach , among other things it puts main and con bearings at risk. The solvent used is 1/10 as hydro-dynamic as even water and also turns oil into a mere shadow of it's former viscosity. I'd use this only in dire situations where oil galley clogging is a probability.
You can use a much lighter weight oil for a short time , such as 0W30 (Mobil) , or even 5W30 , but I wouldn't go driving and boosting (those of us with boost ) on such light weight oil.
Or , you can use a full synthetic oil , they have great detergent properties , but tend to clean seals out so well that the older ones on cars such as ours can spring leaks.
Old Aug 14th, 2004, 11:16 PM   #10 (permalink)
Bror Jace
Nissan Addict
Bror Jace's Avatar
Arrow
I wouldn't use any of the store-bought engine cleaners. As a class, they are better than they used to be but if you use one with too much solvent in it, you might get a bunch of wear and/or a bad seal/leaking problem.
I'd use a 15W-40 gas/diesel motor oil to clean up an older or well-used motor. These dual rated, fleet-type "Heavy Duty Engine Oils" have a very stout detergent/dispersant additive package to keep diesel oil crankcases clean after many thousands of miles. They also have more anti-foamants and more barrier wear additives which make them suitable for high-RPM applications. This weight is also a pretty good one for most high-performance engines.
Months ago, I would have strongly urged you to use Pennzoil Long Life 15W-40 as it had nearly 200PPM of moly in it (more than any other mass-market brand) but very recently, they took the moly out. I'm not sure why.
Chevron Delo400 or pretty much any of them would work fine, I'm sure.
Oh, and not all straight 30 weight oils are non-detergent and ATFs don't necessarily have the high detergency many people think they do. Just wanted to mention that.
Edit - typos & minor changes.
--- Bror Jace
Bror Jace is offline   Reply With Quote
Old Aug 15th, 2004, 03:24 AM   #11 (permalink)
♣300zx♣
♣300zx♣'s Avatar
Originally Posted by Bror Jace
I wouldn't use any of the store bought cleaners. As a class, they are better than they used to be but if you use one with too much solvent in it, you might get a bunch or wear and/or a seal problem.
I'd use a 15W-40 gas/diesel motor oil to clean up an older or well-used motor. These fleet-type "Heavy Duty Engine Oils" have a very stout detergent/dispersant additive package to keep diesel oil crankcases clean after many thousands of miles. They also have more anti-foamants and more barrier wear additives which make them suitable for high-RPM applications. The weight is even a pretty good one for most high-performance engines.
Months ago, I would have strongly urged you to use Pennzoil Long Life 15W-40 as it had nearly 200PPM of moly in it but very recently, they took the moly out.
Chevron Delo400 or pretty much any one would work fine, I'm sure.
Thanks for all the imput-
Old Aug 18th, 2004, 10:16 PM   #12 (permalink)
Bror Jace
Nissan Addict
Bror Jace's Avatar
Thumbs up
♣300zx♣, be sure to tell us how it all works out.
--- Bror Jace
Old Aug 19th, 2004, 10:00 PM   #13 (permalink)
♣300zx♣
♣300zx♣'s Avatar
♣300zx♣
The ticking went away with heaver oil, hey you dont have to call be by♣300zx♣... just call be Simon...Thats my name
Old Aug 20th, 2004, 12:52 AM   #14 (permalink)
TheJackal
am i going to have a problem running 10w30??
oh and where is the blasted oil filter, i swear i looked for it for 10 min and could not find it!
TheJackal is offline   Reply With Quote
Old Aug 20th, 2004, 11:16 AM   #15 (permalink)
JAMESZ
ZPOOLNZ
Send a message via AIM to JAMESZ Send a message via MSN to JAMESZ
Passenger side of the engine you won't be able to see it heh. It is fairly well hidden but with a few seconds of feeling around you will find it. Also don't do this when the engine is hot; then again I assume you know this.
Zpooled Zo Zya
JAMESZ is offline   Reply With Quote
noise from engine at > 2200 RPM labradort Truck & SUV 5 Mar 4th, 2004 03:38 PM
A noise coming from the engine Sethticlees GA16DE 1.6L Engine 11 Oct 6th, 2003 01:14 PM
There Is A Strange Noise In My Engine!! Exalta Off Topic 7 Sep 28th, 2003 10:18 AM
help determining engine noise kbrassfi GA16DE 1.6L Engine 4 Mar 13th, 2003 09:17 PM
Loud engine noise from A/C slei2002se-r B15 2000-2006 0 Nov 9th, 2002 10:11 PM
