found some more problems, need advice
alright guys, i thought that my problems were getting narrowed down, but they jsut keep getting worse. anyways, my main question is: Apparently my rear differential is cracked, what would this cause, mainly? it seems like when i let off of and get on the gas, the car thumps and bounces in the back, like it's not grabbing correctly, or maybe it's shifting around inside. also, when i try to accelerate in a high gear at low RPM's, there is a sort of a low grinding/grumbling noise coming from the back. i'm not really sure how bad the damage is on it, i need to get it checked ASAP. just wondered if anybody had ran into something similar, and had any clue as to what it may be.
another question i had is i replaced my thermostat last night, and it took care of my overheating problems....almost. when i am driving, and putting load on the motor, it runs beautifully, with the temp gauge a tiny bit under midway, never any higher. but, if i stop and leave it running, or get stuck in traffic, the temp gauge goes up fairly quickly, and steam starts coming from my hood. but when i take off again, and start putting load on the motor, it goes right back down. is this a sign of a bad water pump? it's the only thing i can figure might be wrong at this point.
