Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Truck & SUV > X-Trail
Old Dec 20th, 2004, 01:46 PM   #1 (permalink)
andrews
HEAD GASKET PROBLEM
Hi everyone
I own a Xtrail 2/2/2002 with 78.000 klm.Recently they told me that i loose all the water from the tank and from radiator.They told me that the gasket head burned and this is the reason for missing water.
Has anyone heard about that ?And ok i understands that if the head gasket is burned ok i miss water,but why the gasket was burned?
Thanks
andrews
andrews is offline   Reply With Quote
Old Dec 20th, 2004, 07:38 PM   #2 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Hi Andrews.
Welcome to the forum.
Who is this "They" that told you all of this?
If it was a dealer or a repair shop, did they do a compression test on all the cylinders to determine that the motor had a blown head gasket? Maybe there's a coolant leak elsewhere.
George
Old Dec 21st, 2004, 03:41 AM   #3 (permalink)
andrews
Originally Posted by rogoman
Hi Andrews.
George
Says they i mean Nissan official offices in Greece.They told me that they did compression test one month before and there was no problem.In any case they told me that will change the gasket without cost but i am worring about the resaults and the future problems that may occur.
Thanks
Andrews
Old Dec 21st, 2004, 03:56 AM   #4 (permalink)
AVERAGE
Nissan/Mazda Gumshoe
AVERAGE's Avatar
Send a message via MSN to AVERAGE
Thanks
Andrews
if they are going to change it without u having to pay for it, then i wouldnt worry about it. did your truck overheat at anytime. something u might want to check into before they slap on another head gasket.
<a href="http://www.chibangin.com"><img src="http://www.chibangin.com/pics/banner.gif" width="440" height="75" border="0"></a>
AVERAGE is offline   Reply With Quote
Old Dec 22nd, 2004, 01:33 AM   #5 (permalink)
andrews
Hi,
No the truck never overheat !
Old Dec 22nd, 2004, 01:36 AM   #6 (permalink)
andrews
Hi,
Also from the Nissan they told me that maybe the problem was from the bolts of the head and they will change also them with new ones with new DESIGN BOLTS!!!!!
Old Apr 27th, 2005, 05:48 AM   #7 (permalink)
karalisd
Hi! Same problem here, also from greece!
They told me that the coolant goes into the second cylinder! Amazingly the mechanic reached this result after only 5 minutes! He then told me that there has been a recall and a lot of engines were replaced! I get a lot of overheating and the vendilator is working overtime!
I got the car by leasing and they havent told me anything about recalling! Unfortunatelly the leasing ended 2 months ago! I am trying to find out whether my car should have been recalled but i find nothing!
Please advise!
Thanks in advance!
Karalis D.
karalisd is offline   Reply With Quote
Old Apr 27th, 2005, 06:10 AM   #8 (permalink)
xtratime
What engine do you have that is giving these problems ?
xtratime is offline   Reply With Quote
Old Apr 27th, 2005, 06:16 AM   #9 (permalink)
karalisd
the 2.0 liter!
Old Apr 27th, 2005, 08:59 AM   #10 (permalink)
Thorongil
Why did they do a compression test one month before?
Thorongil is offline   Reply With Quote
Old Apr 27th, 2005, 10:47 AM   #11 (permalink)
manuelga
Proud 2004 X-Trail Owner
manuelga's Avatar
Once at Dealership, I knew about a QR25'ed X-Trail, with a blowed gasket, I got my Palm camera & took a gasket pic.
They (dealership guys) told me, it's like a fuse... way much better it damages than the whole engine
manuelga is offline   Reply With Quote
Old Apr 27th, 2005, 02:00 PM   #12 (permalink)
karalisd
spoke to dealer again today and he said that they will probably change the engine free of charge even without guarantee! The engine has cracked and replacing the gasket wont do anything!
Old Apr 27th, 2005, 09:41 PM   #13 (permalink)
Terranismo
Fully Bolted + Juiced!
Terranismo's Avatar
Make sure he not only changes the engine block but also the head, as it most certainly warped out of shape. Double check the engine block number once you get back your truck so you can prove that your engine was indeed changed and not overhauled.
04 X-Trail AWD 5-Speed:06 Engine/2.5' Exhaust & Midpipe/Timing Advance/Knock Sensor Grounded/AEM CAI/SSA Header/ES & Filled Motor Mounts/MP 66mm Throttle Body/JWT BSR Kit/JWT Camshafts/SWA Pulley/Outlaw Engineering Thermoblock Spacers/Grounding Kit/Voltage Stabilizer/Apexi Super AFC II/JWT Flywheel/JWT Clutch/Toyo Proxes S/T 255/55R18 Tires/Arospeed Riot Hyper Gunmetal Wheels 18x7.5/Yokohama Advan Track Tires/Ti Mudguards/Ti Front Halogens/Tinted/Monochrome Black/Debadged/04 Clear Sideblinkers/Nismo Oil Catch Can/ Nismo Reservoir Covers/NOS Wet 60-Shot/NOS Microswitch
Terranismo is offline   Reply With Quote
Old Apr 28th, 2005, 09:33 PM   #14 (permalink)
karalisd
ok! thanks for the advise!
Old Nov 6th, 2007, 03:56 PM   #15 (permalink)
giopap
same problem in greece with my x trail
HELLO I OWN AN X TRAIL SINCE 30/7/02 BOUGHT IN GREECE BRAND NEW. TODAY IT HAS 68.000 KM.
HERE MY STORY COMES.
SIX MONTHS AGO TEMPERATURE INDICATOR WENT TO RED AREA.
I TOOK IT IN MY NEIGHBOURHOOD AUTHORISED SERVICE CENTRE AND THEY TOLD ME THAT THE TANK AND THE RADIATOR WAS OUT OF WATER. I ASKED THEM WHY THIS HAPPENED AND I DINT TAKE A CLEAR ANSWER. LATER ON THEY TOLD ME THAT IT HAS SOMETHING TO DO WITH A RECALL FOR THE CATALYZEITOR MADE BY NISSAN AT 2004 AND IT WAS NOT FIXED AT MY CAR. AT LAST THEY FIXED IT FREE OF CHARGE.
BUT THIS WAS UNFORTUNATELY JUST THE START OF MY ADVENTURE.
WHEN THE CAR CAME BACK TO ME IT WAS OK WITH THE WATER BUT STARTS MAKING A STRANGE METAL SOUND, HEARD FROM THE FRONT WHEELS, I WENT BACK TO THE SERVICE CENTRE AND THEY TOLD ME THAT IF IT WAS WASHED IT WOULD BE OK. THIS SOUND NEVER GONE SINCE THEN BUT I DID NOT GAVE SO MUCH ATTENTION SINCE I THOUGHT IT WAS FROM THE BRAKES.
AND HERE IT COMES THE LAST PART. FIVE DAYS AGO MY X TRAIL LOST AGAIN ALL ITS COOLANT AND AS USUAL I TOOK IT TO SERVICE CENTRE. THE NEWS WAS MORE THAN DISAPPOINTING “CHANGE ENGINE” WAS THE VERDICT AT MY OWN COST OF 10.000 €. I COULD NOT BELIEVE IT AND SO I HAVE CALLED THE NISSANS CUSTOMER SERVICE CENTRE AUTHORISED DEALER FOR GREECE (NIK. I. THEOCHARAKIS AE). AFTER THEY ARE BRIEFING FROM THE MY SERVICE CENTRE TOLD ME THAT IF I FEEL MORE COMFORTABLE I COULD TOOK MY CAR TO THE CENTRAL SERVICE CENTRE. I TOOK THE CHANGE AND WENT THERE. A DAY AFTER THEY SAID TO ME THAT I COULD AVOID CHANGING ENGINE AND JUST CHANGE HEAD GASKET AND SPRINGS AT MY OWN COST AGAIN OF 3.000€.AT MY QUESTIONS ABOUT WHAT IS GOING ON WITH THE ENGINE THEIR ANSWER WAS THAT IS SOMETHING IT HAPPENS AND IS COMMON. I LEFT MY CAR THERE AND GOT BACK HOME VERY SAD AND ANGRY AND MOST OF ALL WITH MY SELF WITCH I TRUSTED NISSAN FIVE YEARS AGO BUYING A NEW FAMILY CAR FOR 34.000 € AND NOW I HAVE NOTHING. PLEASE IF IT IS POSSIBLE SENT ME THE E-MAILS OF THOSE TWO OTHER MEMBERS WITCH HAVE THE SAME PROBLEM WITH ME, MAYBE A CONTACT WITH THEM IT WILL BE VERY HELPFUL.
THANKS A LOT.
giopap is offline   Reply With Quote
Replaced Head Gasket...Timing Chain(s) questions dr69 S14 240SX 1995-1998 4 Dec 8th, 2004 07:17 PM
Cylinder head gasket replacement Sentra GTR-1 GA16DE 1.6L Engine 2 Sep 28th, 2004 05:41 PM
Head Gasket nismosean SR20DE/DET Engines 7 Mar 21st, 2004 03:00 AM
what is the nisom head gasket made of? MyClunkyAss12er E/CA-Series & GA16i Engines 2 Dec 21st, 2003 08:38 PM
SR20DE - internal engine problem after head decking signat New Member Forum 1 Aug 4th, 2003 10:58 AM
