Check Engine Light Code P0135 - Nissan Forum
post #1 of 3 Old Oct 6th, 2010, 08:40 PM Thread Starter
I recently had some engine trouble, my cylinder head and block warped and it was machined. Changed the head gasket also.
However immediately on startup the check engine light remains on.
My mechanic tried resetting the ECM using the method on australian xtrail, however the light comes back on.
He put it in diagnostic mode and the code P0135 comes up which points to - P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
The engine runs fine, just the light remains on.
He suggested to use it for a couple days then try resetting/clearing the code again.
What do you guys think?
Saood is offline
post #2 of 3 Old Oct 7th, 2010, 07:19 AM
X-Trail Moderator
ValBoo's Avatar
I would simply change the #1 O2 sensor. I have had this happen before.
ValBoo.
(QR25DE w/ HS CAI & Header, UR pulley, Timing Advance, SS DP, Magnaflow cat, res & muffler, SS 2.5" exhaust, APEX'i S AFC II, JWT BSR, Tein-S suspension coils drop, A34 SE 18" Mags)
ValBoo is offline
post #3 of 3 Old Oct 7th, 2010, 06:52 PM Thread Starter
Thanks ValBoo, i'm in the process of getting one. All the parts stores i checked here have replacement NGK's, can't seem to find the original Nissan
Saood is offline
  Nissan Forum > Truck & SUV > X-Trail
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
