» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Truck & SUV > X-Trail
Old Jun 30th, 2009, 05:28 PM   #1 (permalink)
flashharry
No power, 3000 rpm max
Hi,
I am wondering if anyone has had experience of a fault my 2003 X-Trail 2.2D Sport has developed.
It starts normally without any difficulty, it ticks over smoothly at the right speed, there's no MI light showing (it does light during the startup test).
The throttle response is wrong. If I push the pedal to the floor the revs increase slowly to about 3000rpm and no further.
I have checked the DTC, no codes.
I have checked the throttle position sensor signals at the ECU and all the voltages are in the range that the service manual specifies.
If I try to drive it, I have to do so with the throttle pedal to the floor and it will do between 20 and 30mph on the flat, slower up hill and faster down hill. It's not labouring and is running smoothly. It's almost as if it is being limited by something.
It smells a bit rich - which is odd for a diesel.
Any suggestions or advice will be most welcome.
Cheers
flashharry is offline   Reply With Quote
Old Jul 3rd, 2009, 05:59 PM   #2 (permalink)
fatman
What mileage have your x-trail done?
When was the last time the fuel filter was replaced?
Fatman
fatman is offline   Reply With Quote
Old Jul 3rd, 2009, 06:26 PM   #3 (permalink)
aussietrail
XTRAIL-HOLIC
aussietrail's Avatar
Send a message via MSN to aussietrail
Sounds like your exy is in limp-mode (fail safe mode) which could mean you have blockage in the EGR valve.
More info. can be found HERE
Cheers,
Jalal (Sydney, Australia)
See my X-Trail HERE
See what we have on offer at the
Australian X-Trail Forum
aussietrail is offline   Reply With Quote
Old Jul 5th, 2009, 07:26 AM   #4 (permalink)
flashharry
Thanks for the suggestions guys, I took it to my Nissan dealer, they diagnosed a throttle position sensor fault. They replaced it and it's working fine.
It was a very expensive part, £450 and it's just a fancy volume control. I am glad to have it back but I would have expected something like this to last for the lifetime of the vehicle. Cheers Nissan.
Old Jul 6th, 2009, 08:26 AM   #5 (permalink)
aussietrail
XTRAIL-HOLIC
Good news. A faulty TPS would have generated an error code for sure, so am surprised when you said no codes were detected.
Cheers,
See my X-Trail HERE
Old Jul 6th, 2009, 08:47 AM   #6 (permalink)
flashharry
The Nissan dealer checked the vehicle over with the Consult II system. I think that this reads the extended codes that my cheapy OBDII reader can't do.
