Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Jul 20th, 2005, 11:16 AM   #1 (permalink)
c_sanjit
Question Engine stops with engine check light on
Hi There,
I own a 1996 Nissan Altima (87,000 mil). Recently encountering a problem. After 45 to 60 minutes drive, when I stop at a signal my engine is shutting down automatically with the engine check light on. Before it stops, there was couple of sparks in RPM indicator. However, I can restart the car immediately.
I recently did the 90,000-mil service.
Any ideas?
Thanks,
SC
c_sanjit is offline   Reply With Quote
Old Jul 20th, 2005, 01:58 PM   #2 (permalink)
LONDONDERRY
Nissan Addict
LONDONDERRY's Avatar
DID YOU GET THE COMPUTER CODES FROM THE ECU? THAT WILL HELP
LONDONDERRY is offline   Reply With Quote
Old Jul 20th, 2005, 10:11 PM   #3 (permalink)
c_sanjit
Thanks for the response. How can I get the computer code from the ECU?
-SC
Old Jul 20th, 2005, 11:26 PM   #4 (permalink)
erik2282
there is a plastic panel you need to remove under the dash, to the right of the gas pedal, behind it is the computer. your gonna see a white sticker that says CAUTION, blah, blah, blah.. your also gonna see a diagnostic mode selector. Turn the ignition to on postion(engine not running), turn the mode selector clockwise with a screwdriver and hold it there for 2 seconds then completely counter clockwise and carefully observe the flashing light on the computer. One some models the "check engine" light on the dash will flash instead of the LED light on the computer. If no codes in computer, you will get a 55 code, which is 5 long flashes, then 5 short flashes. For example if the light flashes 4 long flashes then 3 short flashes, then you got a code 43, get it? Try it and see what codes you get, if any. let me know what u get, i'll tell u the code...
or you could go to auto zone, they hook up the scanner for free and they will tell you the code
erik2282 is offline   Reply With Quote
Old Jul 21st, 2005, 06:26 AM   #5 (permalink)
LONDONDERRY
Nissan Addict
In addition to what erik2282 mentined, it might be a good idea to purchase the Haynes manul for you car.
Old Jul 21st, 2005, 04:18 PM   #6 (permalink)
jserrano
The distributor is probably going bad.
jserrano is offline   Reply With Quote
Is cracked exhaust manifold causing Check Engine Light to come on? MrSparkle Truck & SUV 19 Nov 10th, 2005 05:15 AM
How do I check the code for a check engine light? bonestocksentra QG18 1.8L Engine 2 Sep 22nd, 2004 11:42 AM
check service engine soon light waynekog Truck & SUV 3 Sep 7th, 2004 07:00 PM
check engine light drpepper911 B14 95-99 chassis 14 Jun 19th, 2002 12:57 PM
Check Engine Soon Light? fondoo B14 95-99 chassis 3 May 22nd, 2002 09:33 AM
