Same Problem DTC105 (P1400)
Hi, I recently had the EXACT same problem.
I read the codes from the ECM and tried to find something wrong. Based on the two codes and as a guess, it looked like something in the EGR caused a lean burn which probably caused the knock sensor indication so I focused on the EGR solenoid (looks like the guy that replaced your knock sensor was shot gunning). Everything checked out perfect. So I cleaned the solenoid contacts and the engine ground wires and cleared the codes.
Two trips later MIL light came back on and I checked for codes again. This time just a DTC105 (P1400), so it looks like an intermittent problem in the EGR solenoid or its circuit. The circuit is fairly simple so it's either the solenoid, one of three connectors, or the ECM (I hope not). The connectors are very difficult to get to. I'm debating with myself whether or not to replace the EGR solenoid.
Did you ever get this problem tracked down and fixed??
