Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Mar 26th, 2005, 03:17 PM   #1 (permalink)
wannab-si
erratic check engine light
first off i would like to say hello as a newbe. I just purchased a 1995 altima that has some issues.
to start off, it has an erratic check engine light. this problem seems to be throttle dependent which would lead me to think its a MAF problem(let of the gas and its gone, step on it and its back). when hooked a snap-on scanner up it listed problems with the air intake temp sensor, primary ignition signal fault, and the secondary o2 was sticking on its readings. i replaced the second o2 and the problem is still there. all readings from the distributor/coil and AIT are within specs. if i clear the codes it still has the problem with no codes. i have cleaned off the grounds. the CEL is not allways there. im kinda lost right now so any help would be great
wannab-si is offline   Reply With Quote
Old Mar 26th, 2005, 04:34 PM   #2 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
are there any other running problems? does the engine stumble on or off load? does it idle funny? does it hesitate at all?
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Asleep is offline   Reply With Quote
Old Mar 27th, 2005, 06:07 AM   #3 (permalink)
wannab-si
car runs great. compression is fine....leakdown is fine. i just drove the car over 800mi and got close to 31mpg the whole time. it does idle a little rough,(jumps around 50-70rpms @idle) but the car does have 212,*** mi on it.
Old Mar 27th, 2005, 02:18 PM   #4 (permalink)
Asleep
Asleep's Avatar
im thinking bad wiring... like a loose ground wire or something to that effect. im not a wiring genius though - that and bodywork are my two weakpoints... maybe KA24Tech could shed some light. hes my backup guy.
Old Mar 27th, 2005, 11:33 PM   #5 (permalink)
wannab-si
update on the CEL problem. i took the metal guard off (under valve cover, covers timming chain) because of the chain hitting it. i herd it was a good idea to take this off from a number of people because this guard breaks and can clog the oil pickup.....and the noise was pissing me off. my CEL problem is gone and there are no codes or timming errors. the two codes i was pulling were related to knock and timming. plugs look good and timming is correct.
now my question is, how sensitive are nissan knock sensors? could the chain hitting the guard be interpreted as knock by the computer causing timming to be pulled and the CEL to come?
Old Mar 29th, 2005, 03:09 AM   #6 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
I agree that it is a battery connection or engine ground issue for those codes to pop up. The knock sensor code can occur if the piezo element intercepts anything remotely like a detonation moment. The sensor is shock sensitive but also is effected by the voltage and ground circuit for it's sensitivity. I would pull it off to clean the mount and to test the sensor with an ohmmeter it should measure between 500k and 620k ohms. Then apply an antiseize compound to the bolt and reinstall the sensor torqueing the bolt to between 15 and 20 ft.-lb.. I don't remember the early OBD II being that sophisticated that it would pull timing with a knock signal.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Old Mar 29th, 2005, 03:44 PM   #7 (permalink)
wannab-si
ive gone thru and cleaned all connectors...there was a lot of road salt/dirt in most of the important ones. its gone two days without codes or the check engine light so im assuming the problem is gone.
thanks for the help....
Is cracked exhaust manifold causing Check Engine Light to come on? MrSparkle Truck & SUV 20 Jul 27th, 2008 06:52 PM
How do I check the code for a check engine light? bonestocksentra QG18 1.8L Engine 2 Sep 22nd, 2004 12:42 PM
check service engine soon light waynekog Truck & SUV 3 Sep 7th, 2004 08:00 PM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 22nd, 2003 12:15 AM
Check Engine Soon Light? fondoo B14 95-99 chassis 3 May 22nd, 2002 10:33 AM
