Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Feb 5th, 2005, 11:31 AM   #1 (permalink)
ramccombs
Unhappy '95 Coolant Leak on Engine... Help!!!
I recently replaced the radiator, radiator hoses, and the water pump. A few days after replacing these components I noticed radiator coolant on the transmission and under the car. I can see radiator fluid on the engine and transmission, but cannot tell where it is coming from. It appears to be coming from somewhere near the top of the engine, though. Anyone have any ideas and what it might cost to repair at a shop?
Thanks,
Robert
ramccombs is offline   Reply With Quote
Old Feb 5th, 2005, 04:18 PM   #2 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
Check around the thermostat housing, where the lower water hose and the water pump pipe hose both go into the engine. There are three different gaskets at that junction plus the two hose connections. You should drain the cooling system down a bit and then pull both hoses off to check them inside for swelling or cracks as well as corrosion on the water necks. You may need to replace a hose or two but also consider replacing the thermostat with a new Nissan part at this time if you haven't already and applying new liquid gasket (RTV Silicone) to the housing. Then torque the bolts to 4.7-5.5 ft/lb (M6) or 12-14 ft/lb (M8). Retighten the hose clamps and refill the cooling system. Finally run the engine for a few minutes and check for leaks.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Taiwanese...? Jeff Dallas Nissan Enthusiasts 9 Dec 8th, 2004 08:55 AM
considering 1995 4x4 extended cab purchase. have questions JoanJetta Truck & SUV 39 Dec 31st, 2002 06:39 AM
Coolant Leak....Please help! Mazoku B14 95-99 chassis 3 Dec 30th, 2002 08:52 PM
oil leak on my sentra engine ? vetboy93 B13 91-94 chassis 4 Dec 4th, 2002 10:01 AM
95 Sentra engine swap? rynxprs B14 95-99 chassis 4 May 14th, 2002 08:55 AM
