Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Jan 21st, 2005, 02:26 PM   #1 (permalink)
93-Altima
93 Power Window Problems
Would anyone know where I can find power window replays for a 93 Altima ? The ones that mount in the door.
93-Altima is offline   Reply With Quote
Old Jan 22nd, 2005, 02:36 AM   #2 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
The 93 (and 94) did not have a relay for power, they used a circuit breaker in the constant power side with the power from fusible link G which is under the hood. The circuit breaker is located behind the fuse panel and is a round black can with another side by side.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Old Jan 23rd, 2005, 08:58 PM   #3 (permalink)
93-Altima
Troy,
Thanks for the reply. I might not have identified the part correctly, but this is the information I got from the part.....( Amp Assy, P/WDW, 254240E00 ). It' s by Niles of Japan. This part mounts is each door to control the windows. I have searched the internet, but have not been able to find.
Boudreaux
Old Jan 24th, 2005, 05:03 AM   #4 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
That is the power window amplifier and I thought the driver's side front window used power directly from the main switch but I'll get out my 93 wiring diagram to check...
Troy
SHIFT_Happiness
Old Jan 24th, 2005, 09:28 AM   #5 (permalink)
93-Altima
Would you happen to know a site where I can find this part. Both my rear doors have shorted and now the window goes down, bu not up. So I have them disconnected for now.
Old Jan 25th, 2005, 01:56 AM   #6 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
The master switch sends a data signal to the door power amplifier but each door switch goes into their respective power amp. If you can roll the window from the door switches in back then the power amp is not the problem.
Troy
SHIFT_Happiness
Old Jan 25th, 2005, 09:48 AM   #7 (permalink)
93-Altima
I have traced it down to the power amp. Also removed one from the front door to test. I just can't seem to find this part on the web. I was hoping someone might know where I can find it.
Old Jan 25th, 2005, 11:20 PM   #8 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
Try humoring me by replacing the no. 1 circuit breaker under the fuse panel. This is why I think it is failing because when it is under a big load like when rolling up the window it trips and then resets itself after a short time. The load is rather small when rolling it down. Since you replaced the main switch and the driver's side front window is directly from the main switch and has no power amp. Then since your back windows are having the same problem but do have a power amp for each one of them which power is routed directly from the breaker to the main switch and each one of the power amps. The circuit breaker is the only common link with a good main switch. The power amp is going to be a dealer item if you want to still get one.
Troy
SHIFT_Happiness
1999 altima d/s power window kuo1127 L30 1998-2001 Altima 5 May 31st, 2007 09:21 AM
Problems with fan speed on 93 pathfinder Jibbler Truck & SUV 2 Oct 27th, 2004 02:34 PM
HELP!!!! power window stuck 1/2" down!! xipantera31ix General Discussion 1 Oct 24th, 2004 09:56 PM
93 Path - Power Window Problem tkd4au Truck & SUV 0 Oct 8th, 2004 05:32 PM
Bad contact - power window bwcamp L30 1998-2001 Altima 8 May 25th, 2004 11:35 AM
