Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Jan 13th, 2004, 11:44 PM   #1 (permalink)
PDXOwner
Posts: n/a
Question 95 Altima-Check engine Light
Please Help.
In Oct. my check engine light came on and I took it to a shop to be looked at. They told me after running all the tests, that it was a problem with my mass air flow meter and that would need to be replaced. So I paid the $500 to have the work done and it seemed to fix the problem.
Now this evening when I was coming home from work and it appeared again.
My biggest consern is that I have to travel 10miles in the morning for a meeting and I'm afraid my will break down. Is it okay to drive with this light on. Will it damage my car?
PS. I also noticed that my temp gauge was slightly elivated. It has never gone higher then 1/4 and on my way home it was almost 1/2 way.
Old Jan 22nd, 2004, 10:50 AM   #2 (permalink)
Coco
El Chingon
Coco's Avatar
If they check engine light comes on, you need to get it checked to see what the problem is. You can take it to Autozone and they may be able to tell you what's causing the light to come on. If there is a real problem and you continue to drive, it may cause more problems. Its better to get it checked asap.
.::Coco::.
Coco is offline   Reply With Quote
Old Jan 22nd, 2004, 03:15 PM   #3 (permalink)
ALTYHOLIC
Moderator
ALTYHOLIC's Avatar
Send a message via AIM to ALTYHOLIC
Originally Posted by PDXOwner
Please Help.
Since it's been 3 months since the CEL came on, it could be a new problem,
perhaps a blown 02 sensor...in any event I'd advise getting it to your
dealership asap.
The temp gauge problem could be as simple as installing a new
thermostat. Is the needle going back and fourth a lot?
If the car is still running o.k., I'd say you're o.k. to drive your
10 miles to the meeting and then take it to your dealership.
ALTYHOLIC is offline   Reply With Quote
Old Jan 22nd, 2004, 03:41 PM   #4 (permalink)
Coco
El Chingon
Coco's Avatar
Should be a '95, per the title of his thread.
.::Coco::.
96 nissan altima check engine light troubled in az New Member Forum 0 Oct 4th, 2003 08:19 AM
not sure where this goes...check engine light? Tickwomp Off Topic 4 Jun 11th, 2003 03:41 AM
having trouble with my engine check light palengkeboy S13 240SX 1989-1994 4 Feb 5th, 2003 03:39 PM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 21st, 2003 11:15 PM
check engine light drpepper911 B14 95-99 chassis 14 Jun 19th, 2002 12:57 PM
