Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Altima/Stanza > U13 1993-1997 Altima
Old Dec 2nd, 2003, 02:34 PM   #1 (permalink)
blazebridge
Posts: n/a
Shifting problem
I purchased a 1993 Nissan altima GXE several months ago and have had many problems with shifting. Its an automatic transmission and the car also has a heads-up display for the speedometer. Heres the story:
When I bought the car, I noticed that it delayed shifting from first to second and stayed in second for a LONG time before going to third gear. I took it to a transmission shop and they told me it was my speedometer which wasnt working properly. After they replaced the speedometer they realized that it hadnt fixed the problem, so I went ahead an replaced the speed sensor on the transmission. Still, the same problem. I recently had the transmission rebuilt, and the problem has gotten better but is still there. Its not noticable if I dont accelerate hard. But if I floor it, the problem is still there.
Once the shop realized that the speedometer wasnt the problem, they put the old one back, so its still not working, neither is the heads up display. I considered replacing those, but the Nissan dealership that I took the car to, said that there is no relation between the speedometer and the shifting of the transmission.
So what else could it be? I noticed many posts here about electrical problems, is that the problem.
Thank you in advance for any help or insight in this problem of mine.
Old Dec 2nd, 2003, 09:31 PM   #2 (permalink)
Nismo5042
Send a message via MSN to Nismo5042
there might possibly be a problem with your torque converter. and also does this only do it when you are really getting on it?
Nismo5042 is offline   Reply With Quote
Old Dec 24th, 2003, 07:19 AM   #3 (permalink)
altima25s
altima25s's Avatar
Send a message via AIM to altima25s
Talking
DID YOU BUY MY OLD 93 ALTIMA????? lol Seriously, how long ago did you buy it and is it white with tinted windows??? I seriously had the same problem with mine and this is why i traded it to the dealer (got 4 grand for it, told them it just needed a tune up) and got my 02 altima. I brought that car to EVERY MECHANIC known to man. Even hooked it up to computers ect....welll actually at 1st, i was the only one to feel the problem. At a red light, car would idle rough, then if light turned green and i floored it, the car wouldnt move as fast as it should, sounded as if the car got stuck in the 2nd gear switching to 3rd. God forbid I try to cut someone off, I'd get creamed.
After endless searches on problems. Had tune up, Wires replaced. Tranny flushed, nothing fixed and prob got worse. Then decieded to get a new car, which mind you, is a 5 SPEED I want to control the gears after that expierience. My advice, get rid of it, 1993 was the first yr nissan introduced the altima, TRADE IT!!!! :dumbass:
altima25s is offline   Reply With Quote
Old Jun 19th, 2004, 10:52 AM   #4 (permalink)
Marblecake
Send a message via AIM to Marblecake Send a message via MSN to Marblecake
Was the system bled by chance. Figure i would throw that in there. I would say since its auto bring it to a tranny shop. Not just a normal mechanic.
Marblecake is offline   Reply With Quote
Old Jun 20th, 2004, 04:48 AM   #5 (permalink)
KA24Tech
Biru O' Kudasai
KA24Tech's Avatar
I am thinking it may be associated with the TCU. Check the connections to it and see if the ECU has any stored codes. Take a look at that and then let me know what you find. Also the speed sensor does have an effect on the trans performance but you eliminated that as a possible cause.
Troy
SHIFT_Happiness
1992 S13 240SX SE Fastback KA24DE 5 spd - Type X Aero & Seibon Carbon Hood & Hatch -soon GT28RS
1993 U13 Altima SE KA24DET 5 spd w/ Nismo LSD - A high hp FWD can be fun (GT30R Turbo inside)
1990 Z32 300ZX VG30DETT 5 spd - 600HP & Very Civilized (working on twin GT28RS turbos)
Still trying to import a 1988 R31 Skyline GTS-R w/ RB20DET-R - only 800 produced (legal under show/display regs)
KA24Tech is offline   Reply With Quote
Old Jun 23rd, 2004, 11:25 AM   #6 (permalink)
Cuban_B_93_XE
Cuban_B_93_XE's Avatar
try what ka24 said.
Tearin Up Voorhees, NJ
My Roomate is RUSSIA
http://bicweb.nuclearfallout.net/CubanB.gif
Cuban_B_93_XE is offline   Reply With Quote
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
Minor idling problem dry GA16DE 1.6L Engine 1 Jun 19th, 2003 05:31 PM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
Shifting Problem Zimmy57 GA16DE 1.6L Engine 6 Nov 1st, 2002 02:19 PM
